.. PLA don't stick , warp print
SmalLabs.net
(@smallabs-net)
Hi guys,
I just update to new firmware my mk2.5 always printed very well 5years. Today I have update and now PLA warp and deform .
I tried to:
-Bed calibration (with 3.6 ,3.7 and try to calibrate again)
-change filament another brand
-wash bed with acetone and ipa
-lower pinda
-check all axes screw and belt
-print xyz test cube
-change print setting bed temperature and nozzle too.
-try to downgrade firmware
I don't know what can I try..
Publié : 15/04/2019 6:03 pm
vintagepc
(@vintagepc)
Membre
Re: .. PLA don't stick , warp print
Wash your bed with no-additive (scents, lotions...) dish soap and hot water. Acetone/IPA will not remove fingerprint oils the way they are used, they only smear it out in a thin layer.
Publié : 15/04/2019 6:22 pm
SmalLabs.net
(@smallabs-net)
I try 🤞🏻
Publié : 16/04/2019 12:48 am
SmalLabs.net
(@smallabs-net)
tried ... not worked 🙁 same problem
Publié : 18/04/2019 7:06 pm
vintagepc
(@vintagepc)
Membre
Post a picture of the print after it is finished but still attached to the bed.
Publié : 19/04/2019 5:28 pm
If the PLA isn't sticking, it is contamination of the bed, the filament, or a poor first layer calibration. You've been doing this for a while, long enough to know what a first layer cal looks like, so we're back to contamination. Any chance your filament absorbed a lot of moisture recently? Have you tried a new spool fresh from the bag?
Publié : 19/04/2019 7:25 pm
