Bau verbesserte MMU 2 von karl-herbert
Seite 19 / 19
RE: Bau verbesserte MMU 2 von karl-herbert
My printer is built into a housing. I will send photos the next time the MMU is repaired or serviced, but the connections are described in the PDF file:
BTT SKR MINI E3 V2.0-PIN
wbr,
Karl
Veröffentlicht : 24/08/2025 10:30 pm
kenzo42
(@kenzo42)
That helps so much!
It might just be the angle of the photo, but can you confirm that neopixel is the correct location for the noctua fan? I keep looking at the picture and I can't tell the location of the connector.
Thanks.
Diese r Beitrag wurde geändert Vor 6 months von kenzo42
Veröffentlicht : 25/08/2025 1:22 am
To keep the SKR board cool, I connected the Noctua fan (5V) to GND/PA8 (always on, max. 50 mA). You can also connect and control a 12/24V fan to PC7 or PC6.
Measure the voltages before connecting a fan.
wbr,
Karl
Veröffentlicht : 25/08/2025 6:46 pm
kenzo42
(@kenzo42)
Karl, do you know which Klipper version you used? It seems like some things are deprecated when using the latest Klipper. Thanks.
Veröffentlicht : 30/08/2025 6:21 pm
This clipper/mainsail/moonraker version runs with the config files I published:
wbr,
Karl
Veröffentlicht : 30/08/2025 8:46 pm
Klipper 0.12.0-274 version is running without errors so far, which is why I am no longer performing updates for compatibility reasons.
wbr,
Karl
Veröffentlicht : 30/08/2025 8:50 pm
wbr,
Karl
Veröffentlicht : 30/08/2025 8:53 pm
I forgot to include menu.cfg into klipper config files:
Back up your menu.cfg and copy the new file to folder "/home/pi/klipper/klippy/extras/display/" (overwriting existing menu.cfg).
menu
wbr,
Karl
Veröffentlicht : 30/08/2025 9:06 pm
kenzo42
(@kenzo42)
Thanks Karl. I might be wrong (I searched everywhere), but I don't think there is a repository of older Klipper versions. They're currently on v0.13 which is what I believe I'll have to use.
Veröffentlicht : 30/08/2025 9:50 pm
kenzo42
(@kenzo42)
Just discovered rollback through Kiauh. Will try that out.
Veröffentlicht : 30/08/2025 10:09 pm
Maybe this link will help:
https://klipper.discourse.group/t/how-downgrade-klipper-version/16011/2
wbr,
Karl
Veröffentlicht : 30/08/2025 11:04 pm
kenzo42
(@kenzo42)
I don't know what it is but I just can't get the MCU to connect. Everything went smooth until after I flashed. The flash went fine, Octoprint worked fine, but just Klipper MCU would not connect.
Veröffentlicht : 01/09/2025 5:12 am
kenzo42
(@kenzo42)
Where I placed the files based on your document
Veröffentlicht : 01/09/2025 5:23 am
kenzo42
(@kenzo42)
One more photo.
Veröffentlicht : 01/09/2025 5:26 am
Check klippy.log
You will find detailed information about error messages in klippy.log file.
I am only providing the data as a basis for experimentation and do not offer any support, as I do not have the time for this.
wbr,
Karl
Veröffentlicht : 01/09/2025 8:29 pm
kenzo42
(@kenzo42)
Karl, I got most of it working. Do you think I can use the MMU3 with your Klipper config? Or is it necessary to use your MMU2 modified design? Thanks.
Veröffentlicht : 01/10/2025 2:37 am
kenzo42
(@kenzo42)
Veröffentlicht : 01/10/2025 2:38 am
I haven't tested MMU3, but with various adjustments (pins and software), this is certainly possible.
wbr,
Karl
Veröffentlicht : 01/10/2025 11:48 am
kenzo42
(@kenzo42)
Hi Karl,
I had a question about the MMU setup. When I use [gcode_macro LOAD_FILAMENT_FROM_FINDA_TO_EXTRUDER], I believe it doesn't use the IR sensor to stop the filament at the extruder gears. Rather, it just uses a custom measured distance. Is this correct? I used my finger to press on the door to activate the IR sensor well before it reached the extruder gears, but it does not stop the filament from continuing to load. Am I doing something wrong?
Diese r Beitrag wurde geändert Vor 2 months von kenzo42
Veröffentlicht : 04/12/2025 5:12 am
Seite 19 / 19
