Bau verbesserte MMU 2 von karl-herbert
Page 19 / 19
RE: Bau verbesserte MMU 2 von karl-herbert
My printer is built into a housing. I will send photos the next time the MMU is repaired or serviced, but the connections are described in the PDF file:
BTT SKR MINI E3 V2.0-PIN
wbr,
Karl
Posted : 24/08/2025 10:30 pm
kenzo42
(@kenzo42)
That helps so much!
It might just be the angle of the photo, but can you confirm that neopixel is the correct location for the noctua fan? I keep looking at the picture and I can't tell the location of the connector.
Thanks.
This post was modified 1 month ago by kenzo42
Posted : 25/08/2025 1:22 am
To keep the SKR board cool, I connected the Noctua fan (5V) to GND/PA8 (always on, max. 50 mA). You can also connect and control a 12/24V fan to PC7 or PC6.
Measure the voltages before connecting a fan.
wbr,
Karl
Posted : 25/08/2025 6:46 pm
kenzo42
(@kenzo42)
Karl, do you know which Klipper version you used? It seems like some things are deprecated when using the latest Klipper. Thanks.
Posted : 30/08/2025 6:21 pm
This clipper/mainsail/moonraker version runs with the config files I published:
wbr,
Karl
Posted : 30/08/2025 8:46 pm
Klipper 0.12.0-274 version is running without errors so far, which is why I am no longer performing updates for compatibility reasons.
wbr,
Karl
Posted : 30/08/2025 8:50 pm
wbr,
Karl
Posted : 30/08/2025 8:53 pm
I forgot to include menu.cfg into klipper config files:
Back up your menu.cfg and copy the new file to folder "/home/pi/klipper/klippy/extras/display/" (overwriting existing menu.cfg).
menu
wbr,
Karl
Posted : 30/08/2025 9:06 pm
kenzo42
(@kenzo42)
Thanks Karl. I might be wrong (I searched everywhere), but I don't think there is a repository of older Klipper versions. They're currently on v0.13 which is what I believe I'll have to use.
Posted : 30/08/2025 9:50 pm
kenzo42
(@kenzo42)
Just discovered rollback through Kiauh. Will try that out.
Posted : 30/08/2025 10:09 pm
Maybe this link will help:
https://klipper.discourse.group/t/how-downgrade-klipper-version/16011/2
wbr,
Karl
Posted : 30/08/2025 11:04 pm
kenzo42
(@kenzo42)
I don't know what it is but I just can't get the MCU to connect. Everything went smooth until after I flashed. The flash went fine, Octoprint worked fine, but just Klipper MCU would not connect.
Posted : 01/09/2025 5:12 am
kenzo42
(@kenzo42)
Where I placed the files based on your document
Posted : 01/09/2025 5:23 am
kenzo42
(@kenzo42)
One more photo.
Posted : 01/09/2025 5:26 am
Check klippy.log
You will find detailed information about error messages in klippy.log file.
I am only providing the data as a basis for experimentation and do not offer any support, as I do not have the time for this.
wbr,
Karl
Posted : 01/09/2025 8:29 pm
kenzo42
(@kenzo42)
Karl, I got most of it working. Do you think I can use the MMU3 with your Klipper config? Or is it necessary to use your MMU2 modified design? Thanks.
Posted : 01/10/2025 2:37 am
kenzo42
(@kenzo42)
Posted : 01/10/2025 2:38 am
I haven't tested MMU3, but with various adjustments (pins and software), this is certainly possible.
wbr,
Karl
Posted : 01/10/2025 11:48 am
Page 19 / 19
