Printing Servo Horn 25T
mm_22
(@mm_22)
Mitglied
Hello Forum,
I've been struggling to print a custom servo horn for a 25T spur using PETG in my Prusa XL. Attached is a screenshot in which I've circled the problematic part in turquoise (this is not the servo horn I am trying to print, I am just pointing out the hole/teeth):
Either the hole is entirely too big (the printer skips the teeth), or the hole is too small (the teeth overlap/fuse). I've gotten tips on slowing the print speed and testing/calibrating the filament rate. I've tried the former with no success, and I am about to try the filament calibration.
Besides these two tips, are there any more suggestions for how to print a servo horn with properly sized teeth? Would buying a 0.2 mm nozzle solve this issue?
Thank you
Veröffentlicht : 19/04/2026 7:39 pm
You don't give dimensions but I suspect you are attempting to print features finer than you can extrude.
The smallest feature possible is one extrusion width wide - by default your XL might have a 0.6mm nozzle or a 0.4mm - the default extrusion of a 0.4mm nozzle is 0.45mm wide. A crude minimal gear tooth would be two minimum feature wide - 0.9mm and you have about 40 of them giving a circumference of 36mm and therefore a minimum printable hole diameter diameter of roughly 11.5mm I suspect your server shaft is smaller. Whilst you could, in theory, print finer with a finer nozzle you are not going to get a decent grip.
Instead I suggest printing a shaped, say hexagonal hole that friction fits and then packing the assembly with a setting filler or resin making an insert that grips both parts.
Veröffentlicht : 20/04/2026 3:00 am
Per S.
(@per-s)
Mitglied
RE: Printing Servo Horn 25T
I've been printing quite a few servohorns lately. When I'm in a project I dedicate my MK3.9S to printing these items. Not only servo horns but also gears and other connectors. I pop in the 0.25mm nozzle and design the gear to fit. It usually takes a few iterations to get the perfect fit - shrinkage do vary by filament - but I have yet to not get there.
If I wanted to use my XL, I would do the same. 0.25mm nozzles. You need this to get the details. If I had one smaller than 0.25 I would use it. The resolution increases the smaller nozzle you use. It's logic and physics.
Good luck.
Veröffentlicht : 20/04/2026 6:37 am
mnentwig
(@mnentwig)
If it helps, I printed a servowheel for a Waveshare servo simply using their .step CAD model. Whether the spline was recreated faithfully is matter for debate but the fit was perfect.
I used 0.4 mm PETG IIRC. 0.25 mm doesn't exactly improve strength, you might need to increase temperature over defaults for strength.
Veröffentlicht : 20/04/2026 7:00 am
mm_22
(@mm_22)
Mitglied
What servo gear wheel size? I am trying to print a horn for a 25T wheel. Waveshare has a few different servos. What settings did you use to get the results that you did, with 0.4 mm PETG for the XL?
Thank you
Veröffentlicht : 20/04/2026 8:22 am
mm_22
(@mm_22)
Mitglied
I have never used my XL with nozzles other than the default. If I ordered the 0.25 nozzles in this link, then would I be able to simply plug-n-play (assuming I change the Slicer settings, of course)? Meaning, is changing nozzles on the XL simply a matter of unscrewing and re-screwing, or do other parts need to be ordered/replaced as well?
Thank you
Veröffentlicht : 20/04/2026 8:35 am
mnentwig
(@mnentwig)
Posted by: @mm_22
Thank you
I use Core One but they should be equivalent. Unfortunately, I didn't keep the print, it was just an experiment.
The servo in question is ST3215-HS. I used this step file, loaded it in FreeCAD and exported the wheel (note, it has two - one with spline and a smooth one that acts as a bearing).
If it doesn't fit, just scale the whole print - it won't need more than a few percent.
I used this material but there is nothing special about it. "Generic PETG" temperature probably adjusted to 255°C (as this is the recommended high end)
Veröffentlicht : 20/04/2026 5:31 pm
mnentwig
(@mnentwig)
I did two test prints in 0.4 mm (5 min job). The second one was at 103 % and a very tight fit. 104% or 105 % would probably be optimal.
Under magnification, the spline appears just as a slightly wavy inner wall. But when I attach it to the shaft, it clearly locks in and after first removal, it's nicely shaped.
I'd say it's pretty usable within PETG expectations - probably even better than the stock plastic ones that are often too flexible.
BTW, this is el-cheapo PETG and "almost dry".
Veröffentlicht : 20/04/2026 6:49 pm
Per S.
(@per-s)
Mitglied
Depending on the XL you have. If only one tool, all you need to do is replace the previous nozzle with the new one. Same if you have a 2 or 5 tool version. But here you might neeed to do a tool calibration after changing nozzle to tell the printer how the position of the new nozzle is in relation to all the other nozzles.
I guess if you not are going to use the multi-tool function for the print you don't really need to do this, since the probing and such is done with the same head you're printing with.
Veröffentlicht : 21/04/2026 6:58 am
