Printing multiples on Prusa XL
jj elseser
(@jj-elseser)
I am trying to print two of these parts at once. Slicer is telling me parts are too tall and cannot be printed without extruder collisions... I am printing the selected one first (green highlight) then the orange one towards the back. The parts are only 22mm tall so I do not feel as if there should be a collision. Is there a setting I can change to get this to work properly?
Opublikowany : 24/04/2025 1:36 pm
jj elseser
(@jj-elseser)
UPDATE - I'm not sure why this works, but slicer approved it... These pieces are actually taller than previous as well.. Any input on why this works but previous does not is appreciated
This post was modified 10 months temu by jj elseser
Opublikowany : 23/06/2025 1:23 pm
It's telling you:
The warning triangles in the first picture indicate file geometry errors and at the bottom the number of repairs it has managed plus the information that the data remains invalid - it couldn't fix everything.
Presumably some part of the unfixable geometry references a point too high to skip.
Warning triangles are just warnings, the file *might* be printable but it might not, or it may print strangely.
Usually it's best to go back to the original CAD and make sure you are exporting files correctly optimised for printing.   Some software also has settings for game components or video cgi which require different optimisation, beware.
Your second example either was exported correctly or it may still have had errors but none outside the printable range.
Opublikowany : 23/06/2025 3:56 pm
jj elseser
(@jj-elseser)
RE: Printing multiples on Prusa XL
Thanks - I saw the triangles - never tried to print it though. I exported both through solidworks STL output but who knows maybe I did something different.... :/
Hopefully the new file prints OK since slicer approved it.
Opublikowany : 23/06/2025 6:02 pm
