RE: Xl extruder stops
Just buy a new dwarf board.
Not when there are 4 bad boards and the XL is still under warranty.
Well after going through the suport hoops they had me update to alpha, do a full reset and flash new firmware. Then recalibrate everything only to fail again. I hate that they do the same 1.2.3. Steps every time. Now they sent out a new sandwich board. Should be here in a week and i will update it
Get them replaced under warranty then.
I just printed 12hours with a new board without issues.
Please don't take offense, but are all texts read here?
Some users have already swapped various components (Dwraf, Chees, Buddy,...). A few prints worked flawlessly and then everything started again. This battle of materials is of no use if no components are defective.
If an electronic component is defective, the error would occur permanently and cannot be reset. We have already written that you can skip the error for a few prints.
A temperature-based problem was also ruled out. I and other users tested this several times under different conditions. With enclosure, without, enclosure open, PLA, PA, PC, PETG, PCTG, TPU. Why this? Due to different ambient and electronic temperatures.
I don't understand why people are so persistent about a hardware defect when Prusa has already confirmed that it is a FW problem. The error is supposedly in the ModBus (latest infomation).
I don't know why the error doesn't occur with ALL XL. Neither does Prusa, but that's the way it is.
Yes, the FW is still not there, but I now know with 100% certainty that a FW is already in testing internally. So YES it is being worked on and there is light at the end of the tunnel.
I could vomit that it's taking so long and I'm really pissed because I was apparently one of the first who report the error (June I think) to Prusa support. Only the accumulation and videos of this problem caused Prusa to not ignore it and to investigate it. I'm not registered on GitHub but I don't understand why no one reported the extruder error there.
Hang in there, it looks like this will be solved in 2024.
