Xl extruder stops
Stránka 8 / 16
balloon
(@balloon-2)
RE: Xl extruder stops
Not when there are 4 bad boards and the XL is still under warranty.
Napsal : 14/12/2024 5:24 am
Gary Watkins
(@gary-watkins)
Well after going through the suport hoops they had me update to alpha, do a full reset and flash new firmware. Then recalibrate everything only to fail again. I hate that they do the same 1.2.3. Steps every time. Now they sent out a new sandwich board. Should be here in a week and i will update it
Napsal : 14/12/2024 5:49 am
EvoDesigns
(@evodesigns)
Posted by: @balloon-2
Get them replaced under warranty then.
I just printed 12hours with a new board without issues.
Napsal : 14/12/2024 6:18 am
Gik
 Gik
(@gik)
Posted by: @evodesigns
Just buy a new dwarf board.
Please don't take offense, but are all texts read here?
Some users have already swapped various components (Dwraf, Chees, Buddy,...). A few prints worked flawlessly and then everything started again. This battle of materials is of no use if no components are defective.
If an electronic component is defective, the error would occur permanently and cannot be reset. We have already written that you can skip the error for a few prints.
A temperature-based problem was also ruled out. I and other users tested this several times under different conditions. With enclosure, without, enclosure open, PLA, PA, PC, PETG, PCTG, TPU. Why this? Due to different ambient and electronic temperatures.
I don't understand why people are so persistent about a hardware defect when Prusa has already confirmed that it is a FW problem. The error is supposedly in the ModBus (latest infomation).
I don't know why the error doesn't occur with ALL XL. Neither does Prusa, but that's the way it is.
Yes, the FW is still not there, but I now know with 100% certainty that a FW is already in testing internally. So YES it is being worked on and there is light at the end of the tunnel.
I could vomit that it's taking so long and I'm really pissed because I was apparently one of the first who report the error (June I think) to Prusa support. Only the accumulation and videos of this problem caused Prusa to not ignore it and to investigate it. I'm not registered on GitHub but I don't understand why no one reported the extruder error there.
Hang in there, it looks like this will be solved in 2024.
Napsal : 14/12/2024 9:14 am
2 lidem se líbí
FunCube
(@funcube)
Hello,
After over 300 hours of printing without any issues, I’m encountering a serious problem with my Prusa XL.
Firmware 6.1.3
VIDEO 1 : https://drive.google.com/file/d/1QJHpvAfExyEbboPiqk1p0-9A5YVP6PWa/view?usp=sharing
VIDEO 2 : https://drive.google.com/file/d/1D5FIj3R__p3ETSZupOnn_zWTxflZ7sQ2/view?usp=sharing
The extruder motor is locking up, causing extrusion to stop. Initially, I thought it was a clogged nozzle, but even after replacing it, the problem persists.
I confirmed the blockage by running the XL without the Nextruder cover. I invite you to watch the two videos where the problem occurs as soon as the filament loading procedure begins.
I’ve performed the following tests :
• Full reset
• Replaced the idler parts
• Adjusted the spring tension (both + and -)
• Tried different filaments
• Installed new nozzles
• Checked temperature with an external probe: OK
• Disassembled / degreased / reassembled / lubricated the Nextruder (using the PG-assembly-adapter)
• Extrusion by manually pushing filament with the idler open: OK
• Disconnected all Nextruder connectors, cleaned the connections
You’ll notice that as soon as the “pressure” on the filament is released, either by opening the idler and holding it by hand or by pressing the springs, the motor starts again.
Do you think is the same issue as this topic ? I open a ticket on prusa support, i'm waiting for the return.
Any idea ?
Charles.
Napsal : 14/12/2024 4:28 pm
EvoDesigns
(@evodesigns)
Posted by: @gik
Yup, all texts are ready here and there is multiple problems that people are trying to to jumble into one thread.
Please provide proof that Prusa stated it was a firmware issue and that it's being worked on. I think you mentioned it a month ago but to be honest I doubt they're working on anything. It's gone ignored in the official discord, and they won't chime in here. I've messaged them about it on their support and they don't know anything about it.
Napsal : 14/12/2024 5:28 pm
Gik
 Gik
(@gik)
Yes, I also read that a few problems were mixed up here.
I can't prove it because I don't save every email. I was also expressly told that the conversations were to be treated confidentially. I can only pass this on as I was told.
I do not have access to Prusa's internal structures.
Everyone can think what they want about it.
Napsal : 14/12/2024 8:22 pm
EvoDesigns
(@evodesigns)
Posted by: @gik
So they said, "hey we know the problem, don't tell anyone" got it. Haven't seen them make a statement about it being a firmware issue.
Well, I'm 20 hours in with a new board and I haven't had any issues.
Napsal : 14/12/2024 8:47 pm
FunCube
(@funcube)
Support inform me that, in my case, a board and E motor issue. Need to be swapped in warranty. I ask my official local reseller.
Napsal : 15/12/2024 7:19 am
Gik
 Gik
(@gik)
Posted by: @gik
Um....no.
I can't copy emails or take and upload screenshots. Also, not every line written is intended for a public forum. That's what it means.
But proof would require exactly that.
What about your error? Did you really have the extruder fail at a certain layer height? Where would your evidence be?
Something like that is understandable but ridiculous. We should also trust each other a little here.
Prusa may change components, but not infinitely often. What if something is really defective and Prusa then says, "We've already replaced it once ore twice, so it must be an operator error or installation error?
I only pass on what I can so as not to leave people in the dark. If you like, you can exchange whatever you want with our support team. If it helps, great, if not, bad luck and a risk taken for nothing.
Napsal : 15/12/2024 8:35 am
Fendbass22
(@fendbass22)
Add me to the list. I have 38d print time on mine. T1 extrusion motor keeps stopping about 1-2 hours into every print in the last 2 weeks or so. T2-5 seem to be fine. The weird part is T1 has been my workhorse for a 50 part job that took 9 hours each primarily using T1 but part used all 5 tool heads with zero issues. Not one stop, crash or anything. I kept thinking this was a clog but the cold pulls looked great. Last night I confirmed the motor stops.
I feel like my harness may have been loose at the head but I don't know for sure. I noticed when I disconnected the harness it took longer than I would have thought to produce a red screen error so maybe it's disconnecting long enough to stop some communication process but not enough to trigger a fault? I am super busy so I didn't have time to look into this more.
Another thing - this is the only toolhead where the nozzle LED is flickering like it's on its way out. However, this has been like this since probably 10-12d of run time so I don't think related but it is the only one doing it.
Has anyone successfully replaced a part recommended by tech support that actually solved the problem? I really don't want to call them to get the run around and swap heads around just for them to ignore my issue or say firmware so not sure if worth contacting support.
Napsal : 16/12/2024 1:59 pm
EvoDesigns
(@evodesigns)
Posted by: @fendbass22
I swapped out the dwarf board and the tool has printed about 38ish hours without an issue. Multiple prints with times from 1-7 hours per print. Last night I finished a 6hr multicolor print and it came out perfect. Previously, the T1 head couldn't print longer than 2 hours.
I would request a new board if you're under warranty or buy one if you can. User above your first post says its software/firmware related and he's been waiting since 9/27 with 4 tools as paperweights because he was told it was a firmware issue by support. I haven't seen any mention of it on their github issues or firmware release notes that this is being worked. If I have time, I'll install the old dwarf board on T2 and see what happens.
Also, my T1 LED flickers but iirc, the LED is on the cheeseboard, and it's always flickered on mine. I'll keep printing with the new dwarf board and post any updates if I have any.
Good luck.
Napsal : 16/12/2024 4:38 pm
1 lidem se líbí
Fendbass22
(@fendbass22)
Thank you for the info. After the LiveChat canceled for the 3rd time I think I'm just going to order it and be done.
Napsal : 16/12/2024 11:59 pm
Fendbass22
(@fendbass22)
Update with a support chat I had:
- Told me if you disable the print fan (as a diagnostic measure) you'll find it won't stop the extruder.
- They are sending me a new extruder motor, saying this will solve it for a little while.
- I asked why the issue isn't on the github issues list, they said it will be on a future alpha release.
I don't have a warm and fuzzy feeling about this. I'll try the motor then report back. I am going to get a dwarf too while I'm waiting as it's probably smart to have one around anyway.
Napsal : 17/12/2024 1:57 am
1 lidem se líbí
Nick Collura
(@nick-collura)
"fix it for a little while" that doesn't sound good. Like the motors or power supply or something is operating at the very edge?.?.Been following this problem on Facebook and on here for a while now, and now im just waiting for it to happen to me at this point. I hope the cause is documented somewhere once they have a grasp on what's going on.
Napsal : 17/12/2024 3:06 am
Fendbass22
(@fendbass22)
If the print fan being disabled does let it keep printing then it seems like a current issue. In all my cases where this happened it was changing the tools for multimaterial which keeps starting and stopping the print fan every time it docks. Maybe the ramp is too aggressive, drawing current and causing a comm issue briefly enough to stop extruder?
I am also questioning the firmware version. For the longest time I didn't upgrade my firmware and kept acknowledging at every print there was an update for months but I can't remember if the issue lines up with when I finally upgraded or not.
A few things I want to try:
- Running without the fan as they say. If that's the case then messing with that and speeds or ramp times (firmware, if you can even access it these days)
- Rolling back my firmware a few revisions.
- Extruder motor from support is shipping today, I ordered a dwarf and cable last night just to see if it makes a difference.
I am very lucky right now my jobs to run only need 4 colors/materials.
Napsal : 17/12/2024 2:15 pm
OTR
 OTR
(@otr)
I cannot confirm that it's because of the fan. I had several prints where the extruder stopped long time after the fan was used for the first time, and even not using the fan at all (0% fan in prusaslicer) did not solve the issue. These fans draw some millamps, that should not be an issue anyway.
For me with a multitoolprint it's quite the contrary, because after every parking a tool works again. Mostly. With one print there was an issue where it made some really weird stuff like leaving out complete layers an injecting big blobs of plastic from time to time. But in this case I printed two parts with every tool, and maybe changing from one to the other part created this problem. I havent't checked again, it's tiresome to do the work which Prusa should have done before selling these devices.
Meanwhile 3-4 of my 5 toolheads are infected with this issue, the printer is not really usable anymore. I downgraded to the initial firmware I had when I got the printer (5.9), now one tool which had issues before worked again. But the others still don't work and the printer is degrading to complete uselessness.
Napsal : 17/12/2024 2:45 pm
Fendbass22
(@fendbass22)
Posted by: @otr
I was thinking from the fan starting and stopping when leaving the dock was causing the amperage spikes. However, yes, good point the extruder will re-enable itself on a re-dock.
You can confirm though that shutting the fan off does nothing?
Edit: I come back to a stringy mess so I really don't know when it stopped working, I'm going to have to watch it. This is pretty frustrating. I notice it's mostly silent from Prusa's end.
Napsal : 17/12/2024 3:30 pm
OTR
 OTR
(@otr)
not in my case. But I can check again.
I fully understand what you mean. I should have taken the bambo Carbon X1, but my chef said, "no, we need something professional". Great, now we have bananaware which ripes after buying. Or not, in our case.
Napsal : 17/12/2024 3:52 pm
SailorEric
(@sailoreric)
Well, my two head printer has been a brick for about a month now. It was pretty quirky from the get go with needing work arounds to get it to boot up. Then we developed he issue of just stopping extrusion on both heads. Then the initial boot up just completely crashed. No work arounds helped. They had to admit that the main board was dead and I'm getting to complete extruders and the main board. It has languished in customs for weeks as it's Christmas. Now they have released it and I should have it in a few days. I have to say live chat has been very problematic. Keep timing out and starting anew with the next person who wants to reinvent the wheel all over again. Email is slow, automatic four days every single time. They are way behind the curve on the XL I think. I lost track of the number of times I've reset and gone through all the steps. They seem to have a problem or set of problems they don't know how to address. It has cost us dearly in time, materials, labor and reputation. They don't seem to care. I hope that this fixes things because I've come to a point of washing my hands of Prusa if it doesn't.
Napsal : 18/12/2024 2:18 pm
Stránka 8 / 16
