Prusa XL stops mid print with no errors / warnings
Página 1 / 2
PonyBoy Pop Art
(@ponyboy-pop-art)
I finished installing my Prusa XL and printed the included Batarang GCODE without issue.  I sliced a print of one of my models and when I went to print it, it said that this included a new firmware update, and that my printer would update.  It did.  Since that, I have attempted (3) different prints.  Each one gets about 3-5 hours into the job (each is 10-15 hours depending on the print), and then simply stops.  The progress bar sits at 36% or 29% or similar, and simply waits forever.  I have verified that the GCODE files are completely intact.  I have opened them in GCODE viewer and verified them to be complete.  I have also performed bytewise-comparisons to the sliced files on my laptop with those on the USB drive.  So far, I am using the USB drive that was included with the printer.
Has anyone else experienced this and what is the solution?  I cannot have accept an XL printer that is not capable of printing a job half the size that my M3 can handle with ease.   WTAF?!?!
Respondido : 29/10/2023 9:45 pm
Per S.
(@per-s)
Miembro
RE: Prusa XL stops mid print with no errors / warnings
Do you have the 5.1 Alpha-2 firmware installed? If you do, try to pause the print when it stops/freezes. Most likely it will say it lost contact with the USB stick. Unplug, replug and resume print. And, a snip of the blob created on the print before it bangs into it.
If you have the 4.7.2 I had the same thing happening to me, but I just cancelled the print. Maybe I should just have tried to pause or unplug and replug the USB stick, and then resume print, but I kind of got stressed out so I didn't really think it thru.
After upgrading to 5.1 Alpha-2 and then downgrading to 4.7.2 again (due to instability when I didn't have time for that,) I haven't experienced this.
Also, another thought; try to reformat your USB-stick. FAT32 is the way to go. It might help. Seems to me this problem has to do with the USB-connection getting stuck or lost.
Good luck.
Respondido : 30/10/2023 6:12 am
Lagersuufer
(@lagersuufer)
I've also had this problem with both the 5.1 alpha2 and 4.7.2 firmware, and multiple USB drives. The pause/re-plug USB/resume works in both firmwares, BUT you may lose a layer on your print.
And interesting note, I can print the model just fine as a single color print. But it fails every time, at random points, when I print it as a 5 color print.
Respondido : 30/10/2023 2:15 pm
Per S.
(@per-s)
Miembro
Interesting. I haven't had any problems after downgrading, but it sounds like I've just been lucky. Then again, the only long prints I've done are single colour prints.
Or maybe a freshly formatted USB-drive have, for the time being, helped me .
Respondido : 30/10/2023 5:16 pm
PonyBoy Pop Art
(@ponyboy-pop-art)
I upgraded to firmware v5.1.0alpha and it made it through the night without issue.  If the issue is resolved, I will not leave any more comments, and will presume that v4.7.2 was the problem.
Respondido : 31/10/2023 1:48 pm
PonyBoy Pop Art
(@ponyboy-pop-art)
I had a false moment of hope.  It made it through ONE 16 hour print with v5.1.0Alpha.  Then it started flaking out again.  Sometimes PAUSE/RESUME will work.  Most times, I have to physically pull the USB stick out and re-insert it.
Once I babystep it through the rest of this print, I will try downgrading the firmware AND re-format the USB.
Respondido : 03/11/2023 2:40 pm
GuyH
 GuyH
(@guyh)
Just had the USB drive (Prusa one that came with machine) error on a 8h print. 5 objects, at least one is done for. I'm hoping it completes and the rest are ok. The longer I live with this printer the less I trust it. I cannot afford to run a development machine for Prusa. Contemplating returning it or selling.
EDIT: Thought I'd use the cancel objects to cancel the failed part. The options is greyed out even though I'm running the alpha fw and sliced on the 2.7 beta PS.
Respondido : 13/11/2023 7:46 pm
1Eye
 1Eye
(@1eye)
FYI: I had this issue on multiple attempts for the same print. Each stopped at a different amount of progress. I tried a full power off (hard off at the switch, not a reset) and it did recover after power was restored but the print output was horrible.  It was suggested to me by support to disable Prusa Link to address the problem. So far this has worked for me.
Respondido : 18/11/2023 4:22 am
Jake Reeves
(@jake-reeves)
Miembro
This is the response I received from Prusa Support while troubleshooting the freezing-mid-print error running off USB:
"USB drives that are too large can cause issues, so try to use the ones below 32 Gb. Make sure to not have too many files in the USB. And format the USB to Fat32 (more about it here: https://help.prusa3d.com/article/sd-cards-and-usb-drives_112291 )"
Respondido : 20/03/2024 3:15 pm
BaconFase
(@baconfase)
I've finally come across this error where the printer just pauses for seemingly no reason and the LCD controls are more or less frozen.
As a workaround I just manually force a power panic by pulling the XL's plug from the surge protector for a second then plugging it back in. The XL will rehome X and Y then get back to printing. Worked all four times I've tried so far.
Respondido : 23/03/2024 1:08 am
corycwagner
(@corycwagner)
I have had this issue to and have tried various troubleshooting steps, nothing works:
Here is what I've done based on suggestions in this and other forums:
1. Reformated the thumbdrive
2. Replaced the thumb drive (twice) with better ones
3. Added a Tripplite UPS
4. Pulled the thumbdrive and attached an octoprint device
5. Updated to newest firmware (6.0)
Moving to octoprint reduced the failures, but not by much. I am convinced this isn't a USB issue.
The scary thing about this failure is that when it freezes-up, the hot-end stays heated at the fillament temperature until I reboot the printer. In some cases I don't realize that the printer has locked-up until hours later. So, now it is a safety issue.
I also believe that this behavior only happens on long multicolor prints. Again, no logs. It just freezes mid-print.
I'm updateing you, not for an answer, but to warn you to be careful.
Nothing from Prusa yet. Will update here if issue gets resolve
Any other suggestions are appreciated.
Respondido : 01/05/2024 11:37 pm
goodridm
(@goodridm)
Miembro
I had this happen today at the 48% point of a 3 day print. The printer just stopped at what seemed to be the end of a layer before color change. I noticed the nozzle temp was dropping and Prusa Connect said it was cooling to 70C from 250C. I set it back to 250C and it seemed to heat back up, but no printing resumed. I pressed Pause on the printer and it just seemed to stick at "Pausing...". I couldn't resume form Prusa Connect. The display responded in sound to my clicking, dial moving, but nothing happened. I found your post, pulled the plug and plugged back in. The print job resumed! However, I now have a slight layer shift. 🙁 Pretty disappointing that this issue is not unique.
Respondido : 10/05/2024 1:30 pm
Steve
(@steve)
Just had the same happen to me. 4 hour print with 4 colors .
It just stopped at 33%, halfway a layer, with no errors/messages and started "blobbing".
The display/controls were still responding, so I "paused" the print, which did nothing for about 2 minutes and then it suddenly parked.
So I cut the blob away as best as I could and resumed, and it just started again.
Weird stuff this.
5 tools, firmware 6.0.0+14794 here.
XL (5T) / CORE One / MK3S+-MMU3 / MK3S / Mini / SL1S
Respondido : 14/05/2024 10:36 am
corycwagner
(@corycwagner)
I have registered this as an official bug at the Prusa github.  Please go there and upvote so the devs know how many people this is affecting:
https://github.com/prusa3d/Prusa-Firmware-Buddy/issues/3983
Respondido : 14/05/2024 1:19 pm
2 les gusta
Studio Daniel Rybakken
(@studio-daniel-rybakken)
Miembro
Hello everyone! First time posting on this forum. I had this happen to me yesterday. I had a look at the telemetry and saw that for some strange reason the second, non active nozzle was hot during the entire print. This was a single nozzle print. I ran the same g-code again (but with one of the objects cancel on start to save filament) and this time only the active nozzle was hot, leading me to believe that it was not a problem with the g-code.
Have anyone else checked the telemetry after a failed print and seen this?
Respondido : 19/10/2024 6:09 am
BZH_red
(@bzh_red)
Miembro
Hi, XL T2 here
I'm doing multi material prints with petg and pla as support, and every change of tool is halting the print, the head goes to park the 1st tool, then just stay in front of the parking spot waiting at 240°C...for hours, no error message.
Pausing and unpausing the print via the app works, but for 1 layer... 1500 layers left... And it's been doing this over and over with different Gcodes
The usb is formated and nearly empty, i'm on 6.2.2 firmware.
Respondido : 21/03/2025 12:56 pm
giovanni tauro
(@giovanni-tauro)
Miembro
I have the same issue.  I tried to change the pen drive, re-slice the component. No way. Prusa XL get stucked random at different stages every time you print the same .gcode. It mainly happen whe using multi material prints with PETG and TPU. I hope to solve it, I keep turning on/of and resuming the print LUCKILY.
Firmware: 6.2.5+8912
Respondido : 14/07/2025 7:54 am
Nicholas Beach
(@nicholas-beach)
Miembro
I to am having the problem on 2 different 5TH machines and this is becoming a problem.  Random stop points and can sometimes power interrupt and restart others this does not work.  Is this something Prusa is looking into or has anyone found a cause.  I am still investigating but praying I do not have it again as it is costly to lose filament.
Respondido : 18/09/2025 3:43 pm
mkaay
(@mkaay)
Miembro
Same issue (Firmware6.2.6+8948) - support recommended to try the latest alphae firmware (6.4.0 alpha). I don't think that will help, as I can see that many users have been complaining about this problem for a long time.
Respondido : 02/11/2025 2:01 pm
Roger
(@roger-5)
Just chiming in to say that this has started happening to me in the last few days. I've just updated to the latest firmware (6.4.0+11974).
The first couple of times, I tried the Pause button, but then the interface froze. So I scrapped the job and started again.
The third time, I came searching and found this thread. Thanks everyone - the process of switching the machine off briefly at the power point to perform a power panic worked for me. I'm now 82% through a 26-hour job, having had to go through the process three times so far on this one job. Luckily, each time it's happened, I've "fixed" it before everything cooled down.  Fingers crossed...
This job is a two-filament job on a 5TH machine. When I do the power panic, it re-homes and then changes to next filament. I can't quite tell if that means it's stopping at that point of a filament change, or whether the power panic induces a change. But the toolhead has stopped in the same position every time this has happened (five times so far).
This has never happened in the previous year of using the machine (lightly). Who knows why it suddenly started happening.
Esta publicación ha sido modificada el hace 5 months 3 veces por Roger
Respondido : 11/12/2025 8:33 pm
Página 1 / 2
