Filament change purge too short.
I found that the amount of purging done by the XL on filament change is not enough.
It always only barely come out of the nozzle and then you have to manually go select "Purge more" everytime.
Never had that issue with the mini unless I'm switching from color to white.
I don't suppose there's a way to configure that?
This topic was modified 3 years temu by jF
Opublikowany : 04/10/2023 5:01 pm
