Crash detection can't be activated
Illia Mysiura
(@illia-mysiura)
Good day.
On my Prusha XL (two extruders) for some reason I can't enable crush detection (grey/inactive in the settings).I tried to fix it by installing the latest firmware 6.0.4. with no result.
Do you have any ideas how that can be solved?
Opublikowany : 06/08/2024 10:03 am
BaconFase
(@baconfase)
RE: Crash detection can't be activated
Cant have crash detection enabled at the same time as phase stepping. It's one or the other.
Phase stepping is basically essential to eliminate the noises the XL can make. But if you're like me and have the printer is a different room, so the noises don't matter, then just turn phase stepping off and enable crash detection.
Opublikowany : 07/08/2024 10:47 pm
1 ludzie polubili
Illia Mysiura
(@illia-mysiura)
Thank you very much! That was exactly the problem.
Opublikowany : 08/08/2024 9:08 am
