Control RGB Side Lights?
Hanselcj
(@hanselcj)
Does anyone know how to control the RGB side lights?  I see that you can turn them off in the menu, but I would like to be able to maybe control them via G-code or at least turn them up to high while printing so my camera can see better.  They usually go pretty dim when the print is running.  Maybe this is a feature request.
Posted : 15/07/2023 11:16 am
Racenviper
(@racenviper)
RE: Control RGB Side Lights?
This is the Prusa Article: https://help.prusa3d.com/article/status-led-explained-mk4-xl_418975
Use-defined LED statuses
LEDs can be controlled using a G-code M150, you can learn more about it at Marlin FW site.
Posted : 17/07/2023 2:37 pm
That article seems to be concerned with the lights on the LCD display, not the lights on the side of the XL. I agree with the OP. I would like those light to stay on while printing.
Posted : 17/07/2023 4:27 pm
dmbgo
(@dmbgo)
I also would like to be able to increase the brightness of the XL's lights. I like to be able to see a finished print with my camera.
Posted : 11/05/2024 9:18 pm
