Xl extruder stops
Page 5 / 5
SailorEric
(@sailoreric)
RE: Xl extruder stops
They have decided to replace the Buddy board and both printheads although 5 days since last contact and waiting. They will of course want it run with latest firmware. Honestly after 5 months of all this endless issues this is the last try. After this it's chargeback time and I give up on Prusa. With the money I'll look at a few options in IDEX at the size I need. This has cost us dearly and they don't seem to care.
Publié : 12/11/2024 1:42 am
SteJi et Azulrose ont aimé
SteJi
(@steji)
Posted by: @gik
I hope so too. I don't think every support guy is equally motivated or properly trained.
Let's just hope that the information I received is correct.
I keep my fingers crossed for you.
I don't want to exaggerate, of course, but this is the information I received. Hopefully it's correct and this annoying nightmare will be over.
We got our XL back, so there is another update - and sad news again... after second visit in Prusa factory and lots and lots of promises and reassuring the printer worked for approximately 16 hours. Then it failed in the same way we all know. This time we will have to press for refund. Fortunately Czech law states that if there is valid warranty claim for the same issue for the 3rd time they are obliged to return the money. And believe me, they started to twist like a snake to get out from this situation. This is very, very sad.
Publié : 12/11/2024 2:24 am
SailorEric
(@sailoreric)
Thay have decided I have a bad memory chip as a minimum. They say they are sending the new buddy board and print heads. Now I have to go back and find out if there is a shipping number so I can register it here with customs. Also concerned as the last parts were sent to the wrong address and it took two months to get a thermistor. Will delve into the black hole of live chat in the morning as getting email responses is getting longer and longer. I have to say my confidence in customer support at this point is badly shaken.
Publié : 15/11/2024 12:39 am
Azulrose
(@azulrose)
I just got off chat with support and they've told me the firmware will be out "probably before year end" which is well, quite a bit more than a week. Just dropping this here so everyone can adjust their expectations. I mean, its been more than a week already but, yeah, nebulous ETA at best.
Posted by: @gik
Hello folks!
I finally have some good information from Prusa Support. The extruder failure problem has been fully identified. Firmware is currently being written and will then be tested internally for about a week. Once this is done there will be a firmware on GitHub.
My support keeps me up to date.
Persevere!!!!!
Publié : 15/11/2024 2:17 am
OTR
 OTR
(@otr)
Membre
I've been having the same problem with one of five extruders for about three months. I have a homemade case with a very controlled temperature between 36 and 38 degrees and I can reproduce the error with both the case open and closed. The extruder stopped at exactly the same layer height both times, but I can't say if it was exactly the same line of code. I can also confirm that after stopping the extruder, manual axis commands have no effect, but after briefly parking and retrieving the tools, it works fine again. I've been in contact with Sam from support for a while now, but he still argues it's caused by my enclosure and he wants prove that it's not my fault. I'm pretty angry with Prusa support and would certainly rather buy a Bamoolab next time. Seems that the XL is bananaware that ripes at the customer.
Publié : 15/11/2024 8:38 am
OTR
 OTR
(@otr)
Membre
Just made a 3. try with PLA, no printbed temperature, no change to the gcode except the temperatures, same result. Printer stops at the very same layer height. Means, the failure is at least at my printer neither temperatur nor enclosure related.
Publié : 15/11/2024 5:57 pm
stratocaster
(@stratocaster)
I just returned from a long trip.  I haven’t had time to investigate my “version” of this issue too much.   I am glad to hear that it may be a firmware issue.   I plan on doing some testing to see if I can reproduce this regularly.   I believe I am having this issue with 3 of my extruders.   I plan on contacting support to get on the list of people experiencing  this issue.  Is there any thing I should specifically reference when reporting this issue?  I don’t want to have to go through the “did you trying turning it on and off”’ questions.
Thank you
Carmine
Publié : 16/11/2024 12:19 pm
Azulrose
(@azulrose)
Posted by: @stratocaster
Thank you
Carmine
For most people this error has the following characteristics.
1. Extruder stops mid print, it's unrelated to heat as it happens with the enclosure open or closed and with any material.
2. If you try extruding with the failing print head after the print has been paused or stopped, the gears will not turn
3. If you park the tool and then un-park it, it will now extrude without issue.
4. Many people have found that the issue starts at whichever layer the part fan turns on, and have tested printing without it as a way to sidestep the issue. This doesn't work for everyone.
Support will ask you to perform tests despite the issue being the exact same.
Be prepared to swap extruders around, reclaibrate, and fail again.
My suggestion would be to make a cold pull in every single failing extruder so that you can rule out a clog from the get go.
If two of your extruders still work fine, I'd say don't swap with one of the healthy ones so you can at least keep using your printer if the problem is somehow "contagious" although, in my experience it's just a matter of time before the other ones start having the issue as well, but just in case, keep one safe.
Best of luck!
Publié : 16/11/2024 12:33 pm
Gik
 Gik
(@gik)
Hello folks!
Last update yesterday from Prusa Support: "there was another small "plot twist", but nothing major.
We are still waiting for news and the release of the first firmware that should solve the problem..."
Whatever that means. So we can continue to wait and hope.
However, I have now made it clear to support that it is slowly becoming uninteresting because there is simply no information about the progress or analysis of the problem.
I'll stick with it and continue to annoy them.
Publié : 16/11/2024 1:27 pm
stratocaster
(@stratocaster)
Thank you.   About a month ago I posted the same symptoms on this thread.  I plan on contacting support Monday.
thanks for the advice.
C
Publié : 16/11/2024 7:29 pm
Azulrose
(@azulrose)
Hello everyone, I changed the dwarf boards and that seems to have solved the issue for now.
I had pre-release boards it seems, so if you're still experiencing issues check if yours are too.
They smelled kinda burnt
I'll report back here if anything else changes
Publié : 21/11/2024 11:20 am
Page 5 / 5
