Where are you putting yours?
Strona 2 / 5
trevordj
(@trevordj)
I designed an enclosure with 8020 extrusions, plexiglass sides and front (double layer with an air gap), and aluminum sheet top, back, and bottoms (also double layer with an air gap between. This air gap will be filled with 1" fiberglass insulation). I have all the parts in my garage and am going to try and get it put together in the next week or two.
Opublikowany : 10/06/2023 3:37 pm
3 ludzie polubili
Captain Slow
(@captain-slow)
RE: Where are you putting yours?
I tried to an image of my setup but  option avaible challenge and I could not work out which paper clip looking icon would work. I tried both but no go. Any instructional feedback would be apprecisted
Opublikowany : 17/06/2023 3:19 am
René
(@rene-3)
Use the ADD MEDIA button to add an image to your text.
Opublikowany : 17/06/2023 7:50 am
Sam
 Sam
(@sam-14)
Lack table
Opublikowany : 17/06/2023 6:50 pm
Captain Slow
(@captain-slow)
Opublikowany : 17/06/2023 11:01 pm
Captain Slow
(@captain-slow)
Here I try again.  I reduced the pixel size to below 2500 and all good this time. This image is of my bedroom setup on top of my chest of drawers, all ready and waiting for my XL to arrive.
Opublikowany : 17/06/2023 11:04 pm
Very nice.
Posted by: @traviswilder
I have build this. Top XL - Bottom Mk4+Enclosure. The rolls can be lifted, so it is stable and moveable.
Opublikowany : 20/06/2023 2:04 pm
1 ludzie polubili
TravisWilder
(@traviswilder)
Thanks, the plan is to have the XL on top and the mk4 in enclosure below
Opublikowany : 20/06/2023 2:13 pm
1 ludzie polubili
darksharpie
(@darksharpie)
I realized recently... Be sure that vibrations from one printer can not be felt by the other.  My XL repeatedly failed bed leveling because it's on the same table as an Input Shaping enabled  MK4 while it was printing.  And the MK4 is on 2 concrete pavers with vibration dampeners underneath them.  It still shook the table enough to foil the load cell on the XL.  (I assume the opposite would also be true for starting a MK4 print while the XL is printing something that causes lots of shaking).  I guess i need something softer underneath the pavers to see if that can absorb some more table-shake.
Opublikowany : 21/06/2023 6:30 pm
run_su
(@run_su)
In my garage 😊 10mm steelplate on top and 40 x 80 x 5 mm square iron as legs. In my garage.
This post was modified 2 years temu 2 times by run_su
Opublikowany : 05/10/2023 2:56 pm
1 ludzie polubili
MME
 MME
(@mme)
Mine is on one of my work benches in the office with my CNC and 2 computers. It's a tight space but working out good so far  presently printing the parts for a prototype enclosure.
Its on a base I made with leveling feet.
https://forum.prusa3d.com/forum/original-prusa-xl-tool-changer-user-mods-octoprint-enclosures-nozzles/ideas-to-make-enclosure-for-xl-multi-tool/paged/4/#post-677532
Opublikowany : 06/10/2023 12:02 am
Acht
 Acht
(@acht)
IKEA 😀
Pure Metal construction, cheap and plenty of storage.
Opublikowany : 09/10/2023 9:30 pm
@acht I like it.
Opublikowany : 09/10/2023 9:31 pm
1 ludzie polubili
Jeggo
(@jeggo)
I am going to build a rack in this design:
3030 black aluminium extrusion, MDF board (painted black)  and 3D printed parts.
Place for Ikea 365+ and/or Samla boxes.
Opublikowany : 21/10/2023 9:08 am
stevQ
(@stevq)
My XL currently stands on the office table but I am debating where to "finally" put it:
  • IKEA LACK table
    • + Cheap
    • + About the size it needs
    • - Height is lower than office table
    • - I think it will not be stable enough
  • IKEA Trotten
    • + Seems table
    • + Multiple options e.g. having a shelf above the printer
    • - Is 80 cm wide, which would be great, but no space for that unfortunately in my case
  • IKEA PLASTA
    • + 60 cm wide, which fits for me (but only enough for XL + spools on one side, other side would hang over the edge)
    • + With feet same height as office table
    • - Only 57cm deep, meaning display and back part would overhang
    • --> solution: Remove normal top cover plate and put on a custom wooden plate which is deeper (like 65 to 70cm) but will hang over at the back and front
  • IKEA kitchen part
    • +60 x 60 cm size which seems quite fitting
    • - I don't actually think it is stable enough
    • - Needs a customer wooden plate
    • - Is higher than office table (about 85cm high)
This post was modified 2 years temu by stevQ
Opublikowany : 24/10/2023 9:57 pm
Jeggo
(@jeggo)
For Ikea Trotten, I see the possibility to easily attach an enclosure. I was thinking about polycarbonat sheets with magnets, that could be attached to the steel frame of Trotten. For the back of the XL, you will need some kind of extension, as Trotten is not deep enough. It offers only enough depth for placing the feet of the XL.
Although the Lack table only consists out of painted cardboard, it is quite stable and rigid. I use several Lack tables for quite heavy and big laser printers. Be aware, that the Lack table will only "survive" a long time in dry locations. It sucks humidity like a sponge.
Opublikowany : 25/10/2023 5:52 am
Zappes
(@zappes)
I can only say that the Lack table can become really great with the right modifications. I outlined what I did in this post: https://forum.prusa3d.com/forum/user-mods-enclosures-nozzles/my-lack-table-optimized-for-the-prusa-enclosure/
It's really incredible how sturdy that piece of cardboard becomes with a few brackets and rubber feet.
My models on Printables
Opublikowany : 25/10/2023 1:08 pm
1 ludzie polubili
Razor
(@razor)
What stand is that?
Posted by: @acht
IKEA 😀
Mini+MK3S+XL 5 Tool
Opublikowany : 27/10/2023 10:53 am
Zappes
(@zappes)
That's an IKEA Trotten rack.
Opublikowany : 27/10/2023 10:55 am
2 ludzie polubili
vladimir.aubrecht@me.com
(@vladimir-aubrechtme-com)
I can confirm Ikea Lack can survive Průša XL with single extruder + 1 spool of filament. Having it on top of it like roughly a week, performed like 5 prints and so far it's holding. That said, I think it can work for some time, but it does not feel as a good final solution (stability concerns...) and I am searching something better what would fit my flat ...
Posted by: @stevq
  • IKEA LACK table
    • + Cheap
  • IKEA Trotten
    • + Seems table
  • IKEA PLASTA
  • IKEA kitchen part
Opublikowany : 06/11/2023 12:55 am
Strona 2 / 5
