Nozzle options
What nozzle dimensions, material/coating will there be for this printer and what is the max temperature of the nozzle?
I'm priting a lot with PC-FR,PC-ABS, ASA and ABS
It seems likely that the range will at least replicate everything possible with the MK3 hotends.
I think we can assume that different, specialised, toolheads will appear; let's make some guesses: perhaps one optimised for volume, another for high temperatures, a third for highly abrasive filaments - and so on.
RE: Nozzle options
I could see having a details tool head for the shell, skipping 3 or more infill rows, then swapping out for a fatty nozzle and kicking out a bunch of infill. Also, interested in water soluble for the support interfaces (JUST the interface), and switch out to a 4th setup just to do cheap support structures, rafts, skirts, wipe towers, etc. Only using a small layer or two of the water soluble where the support structure comes in contact with the main shell (aka "support material interface"). Since that stuff is 5-7 times more expensive than other materials that would be fine for support structure part to be thrown away (or recycled), you could really make that water soluble spool last a lot longer. YET, easily separate good supports from your prints.
I could care less about multiple colors, I'm most interested in throwing together 3-5 materials to achieve a high quality print that has little to no post processing effort, with the littlest consumable costs and labor costs as possible 🙂
NOW, for the Slicer to catch up with these great new features coming our way 😉
RE: Nozzle options
This:
Also, it is fair to assume there will be options to print all variations of Prusament. So that gives you an idea of the minimum capabilities.
RE: Nozzle options
There is no information available at this time, more will be released when ready so keep watching!
RE: Nozzle options
SwePoul, I asked the temperature question on Prusa Chat and I was basically given the answer of "To Be Announced". Remember the comment on accessories will be announced before first shipping.
I think they will be holding their cards close until shipping time.
RE: Nozzle options
A nozzle that I've seen in an experiment was called an airbrush nozzle. It is an extension beyond the standard nozzle shape and I believe the concept is to give filament placement travelling paths that are moves in 3 axis directions. I recently came to understand 2.5D printing is different than 3D printing because I was only using the z axis for setting the 2D layer placement height. But the extended and pointed tip nozzle creates opportunity for moves in all 3 axis directions, as long as the extruder and the nozzle never collide into the printed part. Layers would not always necessarily be conformed into planarity with the heat bed and I believe I might have a useful purpose for that functionality.
