Filement clinging to extruder problem
Harley D
(@harley-d)
Hi all,
I'm having continuous problems with filament clinging to the extruder. It does not happen when doing prints at 100% infill, but when I use infill ( anywhere from 15 - 75% ) and/or use supports, the clinging begins.
A while back I got stuck filament problems on some of my filaments ( I use E-sun brand ) particularly the darker ones like black and dark grey. I have carried our several cold breaks to clean the nozzle.
Photos show the proble,. Photos of settings also attached.
Where do I start tackling this problem?
Have others had a similiar experience and if so, how did you fix it?
I have spare nozzles (0.4mm) - would exhanging that fix the problem.
Machine is Prusa XL, manufactured April 2024, imported as a kit.
Opublikowany : 02/11/2025 7:13 pm
That first infill layer mess *looks* like a temperature issue - but ICBW.
Opublikowany : 03/11/2025 12:09 am
Harley D
(@harley-d)
RE: Filement clinging to extruder problem
I changed the infill to Gyroid - no improvement, in fact ot seems worse.
I had to abandon the print after about 1.5mm high.
Opublikowany : 03/11/2025 7:10 pm
