Aplikace Prusa
Vladimir
(@vladimir-3)
Aplikace Prusa
Dobry den.
je nějaká šance aby se v aplikaci Prusa vytvořila knihovna jakých mam filmentu?
Koupil jsem si filament s NFC a i nálepky na ostatní filamenty.
Bylo by dobré vědět jaké druhy filamentu mám a kolik jich cca zbývá…
dekuji
Posted : 14/01/2026 4:06 pm
Rivelino
(@rivelino)
Taky jsem měl představu, že práve sem by to mělo směřovat, aspon evidence skladu. Idealni by jeste bylo pri mmu3 pipnout spulku na tiskarne, zadat pozici na mmu3 a vlozit do dryboxu. Tiskarna by mohla automaticky nacitat odber filamentu tak dlouho, dokud nevyjmes. Pri vymene civky pak dalsim pipnutim  pred ulozenim filamentu zapsat novou hodnotu zbyvajiciho filamentu. Nevim jak je to ale realistické. Zatim nelze ani zapsat novy tag pouzitim .bin na androidu. nezkousel jsem ale jaka je sprava filamentu pokud bych vytvoril tymovou tiskarnu. Ma s tim nekdo zkusenost? Nejsou tam jiz pokrocilejsi funkce?
This post was modified 3 months ago by Rivelino
Posted : 16/01/2026 11:37 am
RE: Aplikace Prusa
Guys (I'm assuming) this is an English speaking forum. If you are posting here do the curtesy of at least running it through google translate
Posted by: @rivelino
I also had an idea that this is where it should go, at least the warehouse records. The ideal would be to beep the spool on the printer with mmu3, enter the position on mmu3 and insert it into the drybox. The printer could automatically read the filament consumption until you remove it. When changing the spool, then with another beep before storing the filament, write the new value of the remaining filament. I don't know how realistic it is. So far, you can't even write a new tag using .bin on Android. I haven't tried it, but what is the filament management like if I were to create a team printer. Does anyone have experience with this? Aren't there more advanced functions?
Posted : 16/01/2026 4:11 pm
Rivelino
(@rivelino)
RE: Aplikace Prusa
i am sorry, I didn't realize that. I have no problem communicating in English. Thank you for the translation.
Posted by: @hyiger
Posted : 16/01/2026 4:31 pm
