RPIOW via Rj45 using prusalink
Patrick.b
(@patrick-b)
Tojik
Stupid question maybe but did i need to set up with the  prusalink img, the SSID and password in the Micro SD card via Raspberry IF i connect the RPIO with the Rj45 cable ethernet?
will the printer give me the ip adress to start the prusalink !! IF i change my router or internet box then i don't care the ssid as well if am still using via RJ45 i mean ?
thx
Posted : 13/11/2023 9:28 am
Tojik
(@tojik)
Member Moderator
RE: RPIOW via Rj45 using prusalink
Hi, no need for SSID and password when using Ethernet. If you change the router, or wifi details, ethernet will still work. Unless you set the box up wrong 😉
Posted : 13/11/2023 10:54 am
Patrick.b liked
