Logitech C270 USB Camera in PrusaLink
Page 1 / 2
moofie
(@moofie)
I've attached a USB camera to the Pi Zero W running PrusaLink, but I don't see any interface to activate it.  When I go to the connect.prusa3d.com on the Camera tab (on another computer), it prompts me to add that computer's webcam.  I'd rather use the camera physically attached to the printer.
Best Answer by Tojik:
Hi, I guess you might be on an old version? If you are on the 0.6.1 - please flash the 0.7.0 available here:  https://github.com/prusa3d/Prusa-Link/releases/tag/0.7.0
If not, you might want to enable ssh and see if you can see the camera in the output of lsusb
Posted : 22/06/2023 12:00 am
Hello
(@hello)
RE: Logitech C270 USB Camera in PrusaLink
make sure you are going to the ip adress no prua connect
Posted : 22/06/2023 2:25 am
moofie
(@moofie)
I couldn’t find any UI in the direct connection to PrusaLink (via the ip address from the display).  Where do I turn on the camera?   It’s plugged in to a microUSB port (via an adapter) to the PiZero attached to Einsy.
Posted : 22/06/2023 2:39 am
Hello
(@hello)
First of all is the adapter data transferable and in the ui in the IP address the is a tab that says camer click that the it should automatically show
Posted : 22/06/2023 9:21 am
Tojik
(@tojik)
Member Moderator
Posted : 22/06/2023 11:54 am
moofie liked
moofie
(@moofie)
Thanks for that.  I just installed PrusaLink two days ago so I presumed that was the latest rev.  I’ll go look at GitHub for an update.
Posted : 22/06/2023 5:36 pm
Tojik
(@tojik)
Member Moderator
Yea, sorry about that, the guide has probably an old version
Posted : 22/06/2023 5:44 pm
moofie
(@moofie)
OK, awesome!  I made some progress.  Installed 0.7.0 and I now have the camera connection interface in PrusaLink (connected locally, trying to get that set up first then I'll wrassle with PrusaConnect).
However, all I get is a window with a thumbnail of a (?) icon in the middle - no image from the camera.  I'm quite dense about Linux (especially multimedia Linux).  Can I telnet to this thing and poke it and make it do stuff?
Posted : 22/06/2023 10:55 pm
moofie
(@moofie)
More detail, I figured out how to ssh into the thing and ran lsusb.  It sure does see the camera:
jo@revoprusa:~ $ lsusb -v -d 046d:081b
Bus 001 Device 003: ID 046d:081b Logitech, Inc. Webcam C310
Couldn't open device, some information will be missing
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass          239 Miscellaneous Device
  bDeviceSubClass         2
  bDeviceProtocol         1 Interface Association
  bMaxPacketSize0        64
  idVendor           0x046d Logitech, Inc.
  idProduct          0x081b Webcam C310
  bcdDevice            0.10
  iManufacturer           0
  iProduct                0
  iSerial                 2 2745D5D0
  bNumConfigurations      1
  Configuration Descriptor:
    bLength                 9
    bDescriptorType         2
    wTotalLength       0x09a5
    bNumInterfaces          4
    bConfigurationValue     1
    iConfiguration          0
    bmAttributes         0x80
      (Bus Powered)
    MaxPower              500mA
    Interface Association:
      bLength                 8
      bDescriptorType        11
      bFirstInterface         0
      bInterfaceCount         2
      bFunctionClass         14 Video
      bFunctionSubClass       3 Video Interface Collection
      bFunctionProtocol       0
      iFunction               0
    Interface Descriptor:
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      bInterfaceClass        14 Video
      bInterfaceSubClass      1 Video Control
      bInterfaceProtocol      0
      iInterface              0
      VideoControl Interface Descriptor:
        bLength                13
        bDescriptorType        36
        bDescriptorSubtype      1 (HEADER)
        bcdUVC               1.00
        wTotalLength       0x009f
        dwClockFrequency       48.000000MHz
        bInCollection           1
        baInterfaceNr( 0)       1
        bLength                18
        bDescriptorType        36
        bDescriptorSubtype      2 (INPUT_TERMINAL)
        bTerminalID             1
        wTerminalType      0x0201 Camera Sensor
        bAssocTerminal          0
        iTerminal               0
        wObjectiveFocalLengthMin      0
        wObjectiveFocalLengthMax      0
        wOcularFocalLength            0
        bControlSize                  3
        bmControls           0x0000000e
          Auto-Exposure Mode
          Auto-Exposure Priority
          Exposure Time (Absolute)
        bLength                11
        bDescriptorType        36
        bDescriptorSubtype      5 (PROCESSING_UNIT)
      Warning: Descriptor too short
        bUnitID                 2
        bSourceID               1
        wMaxMultiplier      16384
        bControlSize            2
        bmControls     0x0000175b
          Brightness
          Contrast
          Saturation
          Sharpness
          White Balance Temperature
          Backlight Compensation
          Gain
          Power Line Frequency
          White Balance Temperature, Auto
        iProcessing             0
        bmVideoStandards     0x1b
          None
          NTSC - 525/60
          SECAM - 625/50
          NTSC - 625/50
        bLength                27
        bDescriptorType        36
        bDescriptorSubtype      6 (EXTENSION_UNIT)
        bUnitID                 3
        guidExtensionCode         {69678ee4-410f-40db-a850-7420d7d8240e}
        bNumControls            8
        bNrInPins               1
        baSourceID( 0)          2
        bControlSize            2
        bmControls( 0)       0x3f
        bmControls( 1)       0x03
        iExtension              0
        bLength                26
        bDescriptorType        36
        bUnitID                 4
        guidExtensionCode         {49e40215-f434-47fe-b158-0e885023e51b}
        bNumControls            2
        bNrInPins               1
        baSourceID( 0)          2
        bControlSize            1
        bmControls( 0)       0x18
        iExtension              0
        bLength                28
        bDescriptorType        36
        bUnitID                 6
        guidExtensionCode         {1f5d4ca9-de11-4487-840d-50933c8ec8d1}
        bNumControls           18
        bNrInPins               1
        baSourceID( 0)          4
        bControlSize            3
        bmControls( 0)       0xff
        bmControls( 1)       0xff
        bmControls( 2)       0x03
        iExtension              0
        bLength                27
        bDescriptorType        36
        bUnitID                 7
        guidExtensionCode         {ffe52d21-8030-4e2c-82d9-f587d00540bd}
        bNumControls            2
        bNrInPins               1
        baSourceID( 0)          4
        bControlSize            2
        bmControls( 0)       0x00
        bmControls( 1)       0x03
        iExtension              0
        bLength                 9
        bDescriptorType        36
        bDescriptorSubtype      3 (OUTPUT_TERMINAL)
        bTerminalID             5
        wTerminalType      0x0101 USB Streaming
        bAssocTerminal          0
        bSourceID               4
        iTerminal               0
      Endpoint Descriptor:
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x87  EP 7 IN
        bmAttributes            3
          Transfer Type            Interrupt
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0010  1x 16 bytes
        bInterval               8
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       0
      bNumEndpoints           0
      bInterfaceSubClass      2 Video Streaming
      iInterface              0
      VideoStreaming Interface Descriptor:
        bLength                            16
        bDescriptorType                    36
        bDescriptorSubtype                  1 (INPUT_HEADER)
        bNumFormats                         3
        wTotalLength                   0x073a
        bEndPointAddress                  129
        bmInfo                              0
        bTerminalLink                       5
        bStillCaptureMethod                 1
        bTriggerSupport                     0
        bTriggerUsage                       0
        bControlSize                        1
        bmaControls( 0)                     0
        bmaControls( 1)                     4
        bmaControls( 2)                     4
        bLength                            27
        bDescriptorType                    36
        bDescriptorSubtype                  4 (FORMAT_UNCOMPRESSED)
        bFormatIndex                        1
        bNumFrameDescriptors               19
        guidFormat                            {32595559-0000-0010-8000-00aa00389b71}
        bBitsPerPixel                      16
        bDefaultFrameIndex                  1
        bAspectRatioX                       0
        bAspectRatioY                       0
        bmInterlaceFlags                 0x00
          Interlaced stream or variable: No
          Fields per frame: 2 fields
          Field 1 first: No
          Field pattern: Field 1 only
        bCopyProtect                        0
        bLength                            50
        bDescriptorType                    36
        bDescriptorSubtype                  5 (FRAME_UNCOMPRESSED)
        bFrameIndex                         1
        bmCapabilities                   0x01
          Still image supported
        wWidth                            640
        wHeight                           480
        dwMinBitRate                 24576000
        dwMaxBitRate                147456000
        dwMaxVideoFrameBufferSize      614400
        dwDefaultFrameInterval         333333
        bFrameIntervalType                  6
        dwFrameInterval( 0)            333333
        dwFrameInterval( 1)            400000
        dwFrameInterval( 2)            500000
        dwFrameInterval( 3)            666666
        dwFrameInterval( 4)           1000000
        dwFrameInterval( 5)           2000000
        bLength                            50
        bDescriptorType                    36
        bFrameIndex                         2
        bmCapabilities                   0x01
        wWidth                            160
        wHeight                           120
        dwMinBitRate                  1536000
        dwMaxBitRate                  9216000
        dwMaxVideoFrameBufferSize       38400
        bLength                            50
        bDescriptorType                    36
        bFrameIndex                         3
        bmCapabilities                   0x01
        wWidth                            176
        wHeight                           144
        dwMinBitRate                  2027520
        dwMaxBitRate                 12165120
        dwMaxVideoFrameBufferSize       50688
        bLength                            50
        bDescriptorType                    36
        bFrameIndex                         4
        bmCapabilities                   0x01
        wWidth                            320
        wHeight                           176
        dwMinBitRate                  4505600
        dwMaxBitRate                 27033600
        dwMaxVideoFrameBufferSize      112640
        bLength                            50
        bDescriptorType                    36
        bFrameIndex                         5
        bmCapabilities                   0x01
        wWidth                            320
        wHeight                           240
        dwMinBitRate                  6144000
        dwMaxBitRate                 36864000
        dwMaxVideoFrameBufferSize      153600
        bLength                            50
        bDescriptorType                    36
        bFrameIndex                         6
        bmCapabilities                   0x01
        wWidth                            352
        wHeight                           288
        dwMinBitRate                  8110080
        dwMaxBitRate                 48660480
        dwMaxVideoFrameBufferSize      202752
        bLength                            50
        bDescriptorType                    36
        bFrameIndex                         7
        bmCapabilities                   0x01
        wWidth                            432
        wHeight                           240
        dwMinBitRate                  8294400
        dwMaxBitRate                 49766400
        dwMaxVideoFrameBufferSize      207360
        bLength                            50
        bDescriptorType                    36
        bFrameIndex                         8
        bmCapabilities                   0x01
        wWidth                            544
        wHeight                           288
        dwMinBitRate                 12533760
        dwMaxBitRate                 75202560
        dwMaxVideoFrameBufferSize      313344
        bLength                            50
        bDescriptorType                    36
        bFrameIndex                         9
        bmCapabilities                   0x01
        wWidth                            640
        wHeight                           360
        dwMinBitRate                 18432000
        dwMaxBitRate                110592000
        dwMaxVideoFrameBufferSize      460800
        bLength                            46
        bDescriptorType                    36
        bFrameIndex                        10
        bmCapabilities                   0x01
        wWidth                            752
        wHeight                           416
        dwMinBitRate                 25026560
        dwMaxBitRate                125132800
        dwMaxVideoFrameBufferSize      625664
        dwDefaultFrameInterval         400000
        bFrameIntervalType                  5
        dwFrameInterval( 0)            400000
        dwFrameInterval( 1)            500000
        dwFrameInterval( 2)            666666
        dwFrameInterval( 3)           1000000
        dwFrameInterval( 4)           2000000
        bLength                            46
        bDescriptorType                    36
        bFrameIndex                        11
        bmCapabilities                   0x01
        wWidth                            800
        wHeight                           448
        dwMinBitRate                 28672000
        dwMaxBitRate                143360000
        dwMaxVideoFrameBufferSize      716800
        bLength                            42
        bDescriptorType                    36
        bFrameIndex                        12
        bmCapabilities                   0x01
        wWidth                            800
        wHeight                           600
        dwMinBitRate                 38400000
        dwMaxBitRate                153600000
        dwMaxVideoFrameBufferSize      960000
        dwDefaultFrameInterval         500000
        bFrameIntervalType                  4
        dwFrameInterval( 0)            500000
        dwFrameInterval( 1)            666666
        dwFrameInterval( 2)           1000000
        dwFrameInterval( 3)           2000000
        bLength                            42
        bDescriptorType                    36
        bFrameIndex                        13
        bmCapabilities                   0x01
        wWidth                            864
        wHeight                           480
        dwMinBitRate                 33177600
        dwMaxBitRate                132710400
        dwMaxVideoFrameBufferSize      829440
        bLength                            38
        bDescriptorType                    36
        bFrameIndex                        14
        bmCapabilities                   0x01
        wWidth                            960
        wHeight                           544
        dwMinBitRate                 41779200
        dwMaxBitRate                125337600
        dwMaxVideoFrameBufferSize     1044480
        dwDefaultFrameInterval         666666
        bFrameIntervalType                  3
        dwFrameInterval( 0)            666666
        dwFrameInterval( 1)           1000000
        dwFrameInterval( 2)           2000000
        bLength                            34
        bDescriptorType                    36
        bFrameIndex                        15
        bmCapabilities                   0x01
        wWidth                            960
        wHeight                           720
        dwMinBitRate                 55296000
        dwMaxVideoFrameBufferSize     1382400
        dwDefaultFrameInterval        1000000
        bFrameIntervalType                  2
        dwFrameInterval( 0)           1000000
        dwFrameInterval( 1)           2000000
        bLength                            34
        bDescriptorType                    36
        bFrameIndex                        16
        bmCapabilities                   0x01
        wWidth                           1024
        wHeight                           576
        dwMinBitRate                 47185920
        dwMaxBitRate                 94371840
        dwMaxVideoFrameBufferSize     1179648
        bLength                            34
        bDescriptorType                    36
        bFrameIndex                        17
        bmCapabilities                   0x01
        wWidth                           1184
        wHeight                           656
        dwMinBitRate                 62136320
        dwMaxBitRate                124272640
        dwMaxVideoFrameBufferSize     1553408
        bLength                            34
        bDescriptorType                    36
        bFrameIndex                        18
        bmCapabilities                   0x01
        wWidth                           1280
        wHeight                           720
        dwMinBitRate                 73728000
        dwMaxVideoFrameBufferSize     1843200
        bLength                            34
        bDescriptorType                    36
        bFrameIndex                        19
        bmCapabilities                   0x01
        wWidth                           1280
        wHeight                           960
        dwMinBitRate                 98304000
        dwMaxBitRate                196608000
        dwMaxVideoFrameBufferSize     2457600
        dwDefaultFrameInterval        2000000
        dwFrameInterval( 0)           1333333
        bLength                             6
        bDescriptorType                    36
        bDescriptorSubtype                 13 (COLORFORMAT)
        bColorPrimaries                     1 (BT.709,sRGB)
        bTransferCharacteristics            1 (BT.709)
        bMatrixCoefficients                 4 (SMPTE 170M (BT.601))
        bLength                            11
        bDescriptorType                    36
        bDescriptorSubtype                  6 (FORMAT_MJPEG)
        bFormatIndex                        2
        bFlags                              1
          Fixed-size samples: Yes
        bAspectRatioX                       0
        bAspectRatioY                       0
          Fields per frame: 1 fields
          Field 1 first: No
        bCopyProtect                        0
        bLength                            50
        bDescriptorType                    36
        bDescriptorSubtype                  7 (FRAME_MJPEG)
        bFrameIndex                         1
        bmCapabilities                   0x01
        wWidth                            640
        wHeight                           480
        bLength                            50
        bDescriptorType                    36
        bFrameIndex                         2
        bmCapabilities                   0x01
        wWidth                            160
        wHeight                           120
        bLength                            50
        bDescriptorType                    36
        bFrameIndex                         3
        bmCapabilities                   0x01
        wWidth                            176
        wHeight                           144
        bLength                            50
        bDescriptorType                    36
        bFrameIndex                         4
        bmCapabilities                   0x01
        wWidth                            320
        wHeight                           176
        bLength                            50
        bDescriptorType                    36
        bFrameIndex                         5
        bmCapabilities                   0x01
        wWidth                            320
        wHeight                           240
        bLength                            50
        bDescriptorType                    36
        bFrameIndex                         6
        bmCapabilities                   0x01
        wWidth                            352
        wHeight                           288
        bLength                            50
        bDescriptorType                    36
        bFrameIndex                         7
        bmCapabilities                   0x01
        wWidth                            432
        wHeight                           240
        bLength                            50
        bDescriptorType                    36
        bFrameIndex                         8
        bmCapabilities                   0x01
        wWidth                            544
        wHeight                           288
        bLength                            50
        bDescriptorType                    36
        bFrameIndex                         9
        bmCapabilities                   0x01
        wWidth                            640
        wHeight                           360
        bLength                            50
        bDescriptorType                    36
        bFrameIndex                        10
        bmCapabilities                   0x01
        wWidth                            752
        wHeight                           416
        dwMaxBitRate                150159360
        bLength                            50
        bDescriptorType                    36
        bFrameIndex                        11
        bmCapabilities                   0x01
        wWidth                            800
        wHeight                           448
        dwMaxBitRate                172032000
        bLength                            50
        bDescriptorType                    36
        bFrameIndex                        12
        bmCapabilities                   0x01
        wWidth                            800
        wHeight                           600
        dwMaxBitRate                230400000
        bLength                            50
        bDescriptorType                    36
        bFrameIndex                        13
        bmCapabilities                   0x01
        wWidth                            864
        wHeight                           480
        dwMaxBitRate                199065600
        bLength                            50
        bDescriptorType                    36
        bFrameIndex                        14
        bmCapabilities                   0x01
        wWidth                            960
        wHeight                           544
        dwMaxBitRate                250675200
        bLength                            50
        bDescriptorType                    36
        bFrameIndex                        15
        bmCapabilities                   0x01
        wWidth                            960
        wHeight                           720
        dwMaxBitRate                331776000
        bLength                            50
        bDescriptorType                    36
        bFrameIndex                        16
        bmCapabilities                   0x01
        wWidth                           1024
        wHeight                           576
        dwMaxBitRate                283115520
        bLength                            50
        bDescriptorType                    36
        bFrameIndex                        17
        bmCapabilities                   0x01
        wWidth                           1184
        wHeight                           656
        dwMaxBitRate                372817920
        bLength                            50
        bDescriptorType                    36
        bFrameIndex                        18
        bmCapabilities                   0x01
        wWidth                           1280
        wHeight                           720
        dwMaxBitRate                442368000
        bLength                            50
        bDescriptorType                    36
        bFrameIndex                        19
        bmCapabilities                   0x01
        wWidth                           1280
        wHeight                           960
        dwMaxBitRate                589824000
        bLength                             6
        bDescriptorType                    36
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       1
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x81  EP 1 IN
        bmAttributes            5
          Transfer Type            Isochronous
          Synch Type               Asynchronous
          Usage Type               Data
        wMaxPacketSize     0x00c0  1x 192 bytes
        bInterval               1
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       2
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            5
          Usage Type               Data
        wMaxPacketSize     0x0180  1x 384 bytes
        bInterval               1
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       3
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            5
          Usage Type               Data
        wMaxPacketSize     0x0200  1x 512 bytes
        bInterval               1
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       4
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            5
          Usage Type               Data
        wMaxPacketSize     0x0280  1x 640 bytes
        bInterval               1
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       5
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            5
          Usage Type               Data
        wMaxPacketSize     0x0320  1x 800 bytes
        bInterval               1
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       6
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            5
          Usage Type               Data
        wMaxPacketSize     0x03b0  1x 944 bytes
        bInterval               1
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       7
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            5
          Usage Type               Data
        wMaxPacketSize     0x0a80  2x 640 bytes
        bInterval               1
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       8
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            5
          Usage Type               Data
        wMaxPacketSize     0x0b20  2x 800 bytes
        bInterval               1
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       9
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            5
          Usage Type               Data
        wMaxPacketSize     0x0be0  2x 992 bytes
        bInterval               1
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting      10
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            5
          Usage Type               Data
        wMaxPacketSize     0x1380  3x 896 bytes
        bInterval               1
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting      11
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            5
          Usage Type               Data
        wMaxPacketSize     0x13fc  3x 1020 bytes
        bInterval               1
      bLength                 8
      bDescriptorType        11
      bFirstInterface         2
      bInterfaceCount         2
      bFunctionClass          1 Audio
      bFunctionSubClass       2 Streaming
      bFunctionProtocol       0
      iFunction               0
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        2
      bAlternateSetting       0
      bNumEndpoints           0
      bInterfaceClass         1 Audio
      bInterfaceSubClass      1 Control Device
      iInterface              0
      AudioControl Interface Descriptor:
        bLength                 9
        bDescriptorType        36
        bcdADC               1.00
        wTotalLength       0x0026
        bInCollection           1
        baInterfaceNr(0)        3
        bLength                12
        bDescriptorType        36
        bTerminalID             1
        wTerminalType      0x0201 Microphone
        bAssocTerminal          0
        bNrChannels             1
        wChannelConfig     0x0000
        iChannelNames           0
        iTerminal               0
        bLength                 9
        bDescriptorType        36
        bTerminalID             3
        bAssocTerminal          1
        bSourceID               5
        iTerminal               0
        bLength                 9
        bDescriptorType        36
        bDescriptorSubtype      6 (FEATURE_UNIT)
        bUnitID                 5
        bSourceID               1
        bControlSize            1
        bmaControls(0)       0x03
          Mute Control
          Volume Control
        bmaControls(1)       0x00
        iFeature                0
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        3
      bAlternateSetting       0
      bNumEndpoints           0
      bInterfaceSubClass      2 Streaming
      iInterface              0
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        3
      bAlternateSetting       1
      bNumEndpoints           1
      iInterface              0
      AudioStreaming Interface Descriptor:
        bLength                 7
        bDescriptorType        36
        bDescriptorSubtype      1 (AS_GENERAL)
        bTerminalLink           3
        bDelay                  1 frames
        wFormatTag         0x0001 PCM
        bLength                11
        bDescriptorType        36
        bDescriptorSubtype      2 (FORMAT_TYPE)
        bFormatType             1 (FORMAT_TYPE_I)
        bNrChannels             1
        bSubframeSize           2
        bBitResolution         16
        bSamFreqType            1 Discrete
        tSamFreq[ 0]        16000
        bLength                 9
        bDescriptorType         5
        bEndpointAddress     0x86  EP 6 IN
        bmAttributes            5
          Usage Type               Data
        wMaxPacketSize     0x0044  1x 68 bytes
        bInterval               4
        bRefresh                0
        bSynchAddress           0
        AudioStreaming Endpoint Descriptor:
          bLength                 7
          bDescriptorType        37
          bDescriptorSubtype      1 (EP_GENERAL)
          bmAttributes         0x01
            Sampling Frequency
          bLockDelayUnits         0 Undefined
          wLockDelay         0x0000
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        3
      bAlternateSetting       2
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType        36
        bTerminalLink           3
        bDelay                  1 frames
        bLength                11
        bDescriptorType        36
        bNrChannels             1
        bSubframeSize           2
        bBitResolution         16
        tSamFreq[ 0]        24000
        bLength                 9
        bDescriptorType         5
        bmAttributes            5
          Usage Type               Data
        wMaxPacketSize     0x0064  1x 100 bytes
        bInterval               4
        bRefresh                0
        bSynchAddress           0
          bLength                 7
          bDescriptorType        37
          bmAttributes         0x01
            Sampling Frequency
          wLockDelay         0x0000
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        3
      bAlternateSetting       3
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType        36
        bTerminalLink           3
        bDelay                  1 frames
        bLength                11
        bDescriptorType        36
        bNrChannels             1
        bSubframeSize           2
        bBitResolution         16
        tSamFreq[ 0]        32000
        bLength                 9
        bDescriptorType         5
        bmAttributes            5
          Usage Type               Data
        wMaxPacketSize     0x0084  1x 132 bytes
        bInterval               4
        bRefresh                0
        bSynchAddress           0
          bLength                 7
          bDescriptorType        37
          bmAttributes         0x01
            Sampling Frequency
          wLockDelay         0x0000
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        3
      bAlternateSetting       4
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType        36
        bTerminalLink           3
        bDelay                  1 frames
        bLength                11
        bDescriptorType        36
        bNrChannels             1
        bSubframeSize           2
        bBitResolution         16
        tSamFreq[ 0]        48000
        bLength                 9
        bDescriptorType         5
        bmAttributes            5
          Usage Type               Data
        wMaxPacketSize     0x00c4  1x 196 bytes
        bInterval               4
        bRefresh                0
        bSynchAddress           0
          bLength                 7
          bDescriptorType        37
          bmAttributes         0x01
            Sampling Frequency
          wLockDelay         0x0000
jo@revoprusa:~ $
Posted : 22/06/2023 11:11 pm
moofie
(@moofie)
OK, I never would have picked that.
Apparently Logitech appends weird headers to jpg's and Safari doesn't like it.
https://github.com/prusa3d/Prusa-Link/issues/610
OK!  so now I just have to hope somebody way smarter than me can fix that bug.
Posted : 23/06/2023 3:43 am
Tojik
(@tojik)
Member Moderator
Okay, should have remembered which camera it was that does this. The logitech webcam I tried did work as expected, so it's not all of them
Posted : 23/06/2023 9:07 am
Tojik
(@tojik)
Member Moderator
What part number does your camera have? Ours has 860-000441 and works almost perfectly. Sometimes a frame is garbled at the end, but it at least sends them.
I would like to get my hands on one that just does not work like yours.
Posted : 23/06/2023 9:14 am
moofie
(@moofie)
As it turns out, I just bought a new one for my incoming Mk4.  Whoops!
Logitech C270 HD Webcam, 720p, Widescreen HD Video Calling,Light Correction, Noise-Reducing Mic, For Skype, FaceTime, Hangouts, WebEx, PC/Mac/Laptop/Macbook/Tablet - Black https://a.co/d/cQZxyMu
Posted : 23/06/2023 1:46 pm
moofie
(@moofie)
Would you like me to mail this one to you?   I’d be happy to do it if that would help.
Posted : 23/06/2023 1:53 pm
Tojik
(@tojik)
Member Moderator
Seems that firmware updates exist for this camera. Would you try and give those a go? https://support.logi.com/hc/en-gb/articles/360024692954--Downloads-HD-Webcam-C270
Posted : 23/06/2023 2:33 pm
moofie liked
Tojik
(@tojik)
Member Moderator
I might have deduced wrong tho.
Anyway, the reason I asked for the part number is because there might have been a HW revision and we might have two different cameras even tho they are labeled the same.
We have to have two different cameras in some way. Because one appears to be working. Or, there's an issue with the prusalink install somewhere
Posted : 23/06/2023 2:37 pm
moofie liked
moofie
(@moofie)
I have a brand spankin' new right out of the box Logitech C270 part number 860-000441.  I ran the https://support.logi.com/hc/en-gb/articles/360024692954--Downloads-HD-Webcam-C27 0" target="_blank" rel="noopener">software installer listed above, and no change to the behavior in PrusaLink. I'm not convinced that the software installer actually did anything to the camera firmware.  I'm going to investigate some more, and try the Windows version to see if that makes a difference.
Posted : 23/06/2023 8:52 pm
Tojik
(@tojik)
Member Moderator
Yea. I don't have windows near this camera. I can borrow the one in the office to tinker with at home, but would prefer not to. There's enough stuff to do :/
Posted : 27/06/2023 11:42 am
moofie liked
moofie
(@moofie)
The Windows package did not seem to install firmware either…it’s software and a driver for the computer end (same as the Mac package).
Posted : 27/06/2023 2:43 pm
THiNK rc
(@think-rc)
Old thread resurrection, but I've been looking at this the past few days, as trying to setup a Multi-Instance PrusaLink.
I have two Mk3S's, currently setup on Pi Zero2's with Octoprint, however wanted to give Prusalink a try out, and figured easy to do a multi-instance with the spare Pi4b I have to hand. Both printers have C270's linked to them (I have four of these cams in total). However, setting up the cameras, run into the same problem, in that which ever came I plugged in, it would 'switch', like there was literally no difference. Couldn't get PrusaConnect to register them seperately at all.
Having had some email comm's with Chris Riley (as he had done a good video on multi cam setups with C270's), did some digging, and have realised that three of the four C270's I have are registering the exact same serial number. Easy to see if you jump into SSH and run journalctl |grep usb. The fourth C270 I have has it's own unique number, but is also the oldest of the four. So seems like Logitech made a change in the last couple of years to the inbuilt serials of the C270 cameras. Hence newer don't work, but older do.
Anyway, I'm now off to switch out one of the matchy serial cameras with the only other unique one and see if that works!
THiNK Fast
Posted : 02/12/2024 1:21 pm
Page 1 / 2
