connect.prusa3d.com/error/403/no-early-access/
MarkusRe
(@markusre)
I can run the wizard on the Pi, but after login into connect.prusa3d.com no function are displayed and the url is https://connect.prusa3d.com/error/403/no-early-access/
Whats wrong wiht my account?
Respondido : 09/03/2022 9:10 pm
1 les gusta
Tojik
(@tojik)
Miembro Moderator
RE: connect.prusa3d.com/error/403/no-early-access/
Hi, can confirm, unfortunately, there is a little chance to fix it off-hours. Sorry for the wait. PrusaLink should work without Connect too tho. You can still view and print the files, just through the little simpler local UI
Respondido : 09/03/2022 9:36 pm
Tojik
(@tojik)
Miembro Moderator
Fixed
Respondido : 10/03/2022 10:01 am
bapski
(@bapski)
Has anyone tried Prusa Connect?
Im at work and can't physically try it right now and just going through the process. The part where it says to install the Prusa Link addon is confusing me. Is this an Octoprint addon? I searched octoprint plugins and it ia not listed.
I followed the link to the instructions and although i have a Pi3b+ nothing is outlined how to install or use the Prusa Link addon.
All i see to make the connection is to just type the Printers IP address, and if i do this, i know ill come up with an Octoprint page.
MY MODELS AT PRINTABLES
Respondido : 10/03/2022 3:12 pm
McBig
(@mcbig)
Miembro
PrusaLink is not OctoPrint addon, it is own Printing/Controlling SW for MK3. It was written from zero, and it's main future is connect MK3 to PrusaConnect.
For more information see https://help.prusa3d.com/en/guide/prusalink-and-prusa-connect-mk3s-mk3s_221744
Both of software Link and Connect are still in Beta 😉
Respondido : 10/03/2022 7:54 pm
1 les gusta
bapski
(@bapski)
thank you. i just realized they are not one and the same. i'd have to have a new Pi image and add a config.ini file.
p.s.
good that i checked out the link that you have provided. instructions on the link are more precise than the other link i went to. thanks again.
Respondido : 10/03/2022 8:15 pm
1 les gusta
