First Layer issues
Pagina 2 / 2
SgtCaffran
(@sgtcaffran)
RE: First Layer issues
For me, the Mk4 has been nothing else than fire and forget. It lays down an amazing first layer every time!
Postato : 14/08/2023 8:56 pm
OB1
 OB1
(@ob1)
But that’s the worst possible solution  who knows whether u have to raise or lower the live Z before it starts printing - the load sensor is not always “too high” or “too low” - it’s not predictable … and who wants to do live-Z for every single print… that’s so last decade 🙂
Posted by: @pars3c
Keep the knob pressed when it moves from the bottom left corner to the print area, before it starts the first layer (or even after it started). You can adjust live z
Postato : 14/08/2023 9:21 pm
OB1
 OB1
(@ob1)
Show off 🙂
To me it’s a tolerance issue with too much random dependencies on cleanliness of nozzles, filament type (eg how much it oozes) and load sensor sensitivities. For some, it will work, for some it won’t
Posted by: @sgtcaffran
Postato : 14/08/2023 9:24 pm
MarcWinNJ
(@marcwinnj)
You dont have an MK4 do you?
Postato : 14/08/2023 9:28 pm
SgtCaffran
(@sgtcaffran)
Don't want to draw attention away from complaints! Just want to give a positive example that when it works, it works really well and reliable. Can't say what's wrong of course
Have only printed PLA so far so definitely not tried the entire range of possibilities!
Postato : 14/08/2023 9:59 pm
Utenti
Same here as long as I use the smooth sheet.  I will let you know how well the texture works next weekend.
Postato : 14/08/2023 10:44 pm
the-powl
(@the-powl)
same for me
Postato : 04/09/2023 9:52 pm
Utenti
I can tell you the textured sheet works well on the MK4.  I have tired it with ABS.,
Postato : 04/09/2023 11:46 pm
1 persone hanno apprezzato
Stigern
(@stigern)
Also had severe first layer problems on my mk4, factory assembled.
I had to adjust my nozzle, loosened the two screws and every so slightly moved it closer to bed. And re-tightened.
Not sure if thats the correct way but it seems to help.
Questo post è stato modificato 3 years fa 2 tempo da Stigern
Postato : 06/11/2023 7:41 pm
Pagina 2 / 2
