					                		Bgcode files not recognised - Input Shaper (MK4)                                    </title>
                <link>https://forum.prusa3d.com/forum/input-shaping/bgcode-files-not-recognised/</link>
                <lastBuildDate>Sat, 11 Apr 2026 21:33:16 +0000</lastBuildDate>
                        <title>RE: Bgcode files not recognised</title>
                        <link>https://forum.prusa3d.com/forum/input-shaping/bgcode-files-not-recognised/#post-710932</link>
                        <pubDate>Tue, 14 May 2024 02:32:34 +0000</pubDate>
                        <description><![CDATA[Ive been going through the ringer i think under the same scenarios above, when you say remove the &quot;#&quot; is it from the files name it gets exported to save onto computer or USB memory stick etc...]]></description>
                        <content:encoded><![CDATA[<p>Ive been going through the ringer i think under the same scenarios above, when you say remove the "#" is it from the files name it gets exported to save onto computer or USB memory stick etc etc saving device one is using ?? TIA </p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/input-shaping/">Input Shaper (MK4)</category>                        <dc:creator>WUSTANG Build</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/input-shaping/bgcode-files-not-recognised/#post-710932</guid>
                        <link>https://forum.prusa3d.com/forum/input-shaping/bgcode-files-not-recognised/#post-707830</link>
                        <pubDate>Tue, 16 Apr 2024 12:09:01 +0000</pubDate>
                        <description><![CDATA[Addition:if the filename contains a &quot;#&quot; (hashtag) it also causes this error. Has been driving me mad half the day.]]></description>
                        <content:encoded><![CDATA[<p>Addition:</p><p>if the filename contains a "#" (hashtag) it also causes this error. Has been driving me mad half the day.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/input-shaping/">Input Shaper (MK4)</category>                        <dc:creator>Alveon</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/input-shaping/bgcode-files-not-recognised/#post-707830</guid>
                        <link>https://forum.prusa3d.com/forum/input-shaping/bgcode-files-not-recognised/#post-698166</link>
                        <pubDate>Wed, 07 Feb 2024 20:04:30 +0000</pubDate>
                        <description><![CDATA[there is also a maximum character limit on file names from other posts/issues I&#039;ve read.  Regardless of file type.]]></description>
                        <content:encoded><![CDATA[<p>there is also a maximum character limit on file names from other posts/issues I've read.  Regardless of file type.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/input-shaping/">Input Shaper (MK4)</category>                        <dc:creator>Neophyl</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/input-shaping/bgcode-files-not-recognised/#post-698166</guid>
                        <link>https://forum.prusa3d.com/forum/input-shaping/bgcode-files-not-recognised/#post-698154</link>
                        <pubDate>Wed, 07 Feb 2024 18:14:54 +0000</pubDate>
                        <description><![CDATA[Here the same problem, sometimes, not always. Also when using gcode files. Changing the filename (I usually make it shorter) and the file is accepted. So it has to do with the filename, not ...]]></description>
                        <content:encoded><![CDATA[<p>Here the same problem, sometimes, not always. Also when using gcode files. Changing the filename (I usually make it shorter) and the file is accepted. So it has to do with the filename, not the content of the file. A bit strange.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/input-shaping/">Input Shaper (MK4)</category>                        <dc:creator>wtmspijker</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/input-shaping/bgcode-files-not-recognised/#post-698154</guid>
                        <link>https://forum.prusa3d.com/forum/input-shaping/bgcode-files-not-recognised/#post-695218</link>
                        <pubDate>Fri, 19 Jan 2024 20:00:48 +0000</pubDate>
                        <description><![CDATA[For me it did not recognize the Prusa generated filename. I changed it to biteme.bgcode and all is fine.]]></description>
                        <content:encoded><![CDATA[<p>For me it did not recognize the Prusa generated filename. I changed it to biteme.bgcode and all is fine.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/input-shaping/">Input Shaper (MK4)</category>                        <dc:creator>XL beta tester for far too long</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/input-shaping/bgcode-files-not-recognised/#post-695218</guid>
                        <link>https://forum.prusa3d.com/forum/input-shaping/bgcode-files-not-recognised/#post-689801</link>
                        <pubDate>Sun, 17 Dec 2023 00:05:48 +0000</pubDate>
                        <description><![CDATA[OK, figured it out.  Need to do the following:Menu:Configuration/Mode/Expert.Tab/Window: Printer Settings/General/Supports Binary G-code - Unselect.]]></description>
                        <content:encoded><![CDATA[<p>OK, figured it out.  Need to do the following:</p><p>Menu:Configuration/Mode/Expert.</p><p>Tab/Window: Printer Settings/General/Supports Binary G-code - Unselect.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/input-shaping/">Input Shaper (MK4)</category>                        <dc:creator>Cusack Music</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/input-shaping/bgcode-files-not-recognised/#post-689801</guid>
                        <link>https://forum.prusa3d.com/forum/input-shaping/bgcode-files-not-recognised/#post-689799</link>
                        <pubDate>Sat, 16 Dec 2023 23:49:13 +0000</pubDate>
                        <description><![CDATA[I&#039;m having the same issue.  Just downloaded newest firmware 5 miuntes ago, and it doesn&#039;t recognize it.  Also the menu I&#039;m being told to go to to turn it off does not exsist in the slicer.  ...]]></description>
                        <content:encoded><![CDATA[<p>I'm having the same issue.  Just downloaded newest firmware 5 miuntes ago, and it doesn't recognize it.  Also the menu I'm being told to go to to turn it off does not exsist in the slicer.  Anybody else have ideas?</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/input-shaping/bgcode-files-not-recognised/#post-689799</guid>
                        <link>https://forum.prusa3d.com/forum/input-shaping/bgcode-files-not-recognised/#post-689088</link>
                        <pubDate>Tue, 12 Dec 2023 16:48:25 +0000</pubDate>
                        <description><![CDATA[Anyway, it&#039;s quite simple to export files as ASCII gcode, regardless of the firmware version.
Go to ’Printing configuration’ in the menu. Click on  ‘output settings’ and see if the tab ‘exp...]]></description>
                        <content:encoded><![CDATA[<p>Anyway, it's quite simple to export files as ASCII gcode, regardless of the firmware version.</p>
<p>Go to ’Printing configuration’ in the menu. Click on  ‘output settings’ and see if the tab ‘export as binary gcode’ is enabled. If so, just uncheck it and the file will be sent to the printer as ordinary ASCII gcode instead of binary bgode.  (You must be on 'expert' mode to see this option on the menu ).</p>
                        <category domain="https://forum.prusa3d.com/forum/input-shaping/">Input Shaper (MK4)</category>                        <dc:creator>Artur5</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/input-shaping/bgcode-files-not-recognised/#post-689088</guid>
                        <link>https://forum.prusa3d.com/forum/input-shaping/bgcode-files-not-recognised/#post-689085</link>
                        <pubDate>Tue, 12 Dec 2023 16:31:06 +0000</pubDate>
                        <description><![CDATA[You have to be on firmware 5.1.0 or your printer has no idea what a bgcode file is.]]></description>
                        <content:encoded><![CDATA[<p>You have to be on firmware 5.1.0 or your printer has no idea what a bgcode file is.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/input-shaping/">Input Shaper (MK4)</category>                        <dc:creator>FoxRun3D</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/input-shaping/bgcode-files-not-recognised/#post-689085</guid>
                        <link>https://forum.prusa3d.com/forum/input-shaping/bgcode-files-not-recognised/#post-689070</link>
                        <pubDate>Tue, 12 Dec 2023 15:05:21 +0000</pubDate>
                        <description><![CDATA[Which firmware version for the MK4 are you using?]]></description>
                        <content:encoded><![CDATA[<p>Which firmware version for the MK4 are you using?</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/input-shaping/">Input Shaper (MK4)</category>                        <dc:creator>Zwirbel</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/input-shaping/bgcode-files-not-recognised/#post-689070</guid>
