Better quality prints after IS adjustment, esepcially on low poly models
I don't take credit for this, that goes to shledge on discord, but wanted to post this to the official forum to hopefully bring attention to it.
After adjusting PA, able to get better quality prints, most notably on low poly models. The corners have less rounding/the edges are less bulbous.
M572 S0.06 M572 W0.01 M593 X T2 F45 D0.06 Mf93 Y T2 F40 D0.06
Before and after:
Here's a 3mf of a project that has the above tweaks made to the gcode with some additional adjustments over stock profiles: https://www.dropbox.com/scl/fi/hatrl1fp499tkxpspasv7/ash_IS_0.2mm.3mf?rlkey=mb7y5uobw8gukmpoy3vsjbgsz&dl=0
RE: Better quality prints after IS adjustment, esepcially on low poly models
You are still using stock PA value (0.038). Your custom value was added to the start g-code, which is then overriden by default value from filament profile. I don´t know what filament are you using, but 0.06 will be almost certainly too big value for PLA.
The main reason for better quality on your printer is likely small acceleration for external perimeters (half).
