					                		Print quality - PETG with IS - Input Shaper (MINI)                                    </title>
                <link>https://forum.prusa3d.com/forum/input-shaper-mini/print-quality-petg-with-is/</link>
                <lastBuildDate>Tue, 16 Jun 2026 09:55:04 +0000</lastBuildDate>
                        <title>RE: Print quality - PETG with IS</title>
                        <link>https://forum.prusa3d.com/forum/input-shaper-mini/print-quality-petg-with-is/#post-698224</link>
                        <pubDate>Thu, 08 Feb 2024 07:58:31 +0000</pubDate>
                        <description><![CDATA[Oh, my settings are for the MK4, I just now realized you have a Mini. I don&#039;t know the proper absolute values for that device, but the general idea of reducing the setting seems transferable...]]></description>
                        <content:encoded><![CDATA[<p>Oh, my settings are for the MK4, I just now realized you have a Mini. I don't know the proper absolute values for that device, but the general idea of reducing the setting seems transferable. :)</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/input-shaper-mini/">Input Shaper (MINI)</category>                        <dc:creator>Zappes</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/input-shaper-mini/print-quality-petg-with-is/#post-698224</guid>
                        <link>https://forum.prusa3d.com/forum/input-shaper-mini/print-quality-petg-with-is/#post-698223</link>
                        <pubDate>Thu, 08 Feb 2024 07:57:18 +0000</pubDate>
                        <description><![CDATA[@toddg: Yes, I meant retraction. The stock Prusament PETG profile has an override for that which sets it to 0,8mm:0,8mm is OK for most prints, but when you get little blobs where the extrude...]]></description>
                        <content:encoded><![CDATA[<p>@toddg: Yes, I meant retraction. The stock Prusament PETG profile has an override for that which sets it to 0,8mm:</p><p><a href="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2024/02/4432c767-2024-02-08-08_54_48-_untitled-prusaslicer-2.7.1-based-on-slic3r.jpg"><img class="alignnone size-medium wp-image-163491" src="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2024/02/4432c767-2024-02-08-08_54_48-_untitled-prusaslicer-2.7.1-based-on-slic3r-600x500.jpg" alt="" width="600" height="500" /></a></p><p>0,8mm is OK for most prints, but when you get little blobs where the extruder stops extruding, it's a great idea to reduce this. I had very good results with 0,2mm for my <a href="https://www.printables.com/model/747742-minimal-gridfinity-6u-bins-parametric" target="_blank" rel="noopener">rather tricky minimal gridfinity bins</a>.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/input-shaper-mini/print-quality-petg-with-is/#post-698223</guid>
                        <link>https://forum.prusa3d.com/forum/input-shaper-mini/print-quality-petg-with-is/#post-698188</link>
                        <pubDate>Wed, 07 Feb 2024 23:41:57 +0000</pubDate>
                        <description><![CDATA[That&#039;s a lot of retraction, with dry filament .8 is plenty. I took the prusament PETG profile and updated the filament diameter to match what I measured on the actual roll of material and up...]]></description>
                        <content:encoded><![CDATA[<p>That's a lot of retraction, with dry filament .8 is plenty. </p><p>I took the prusament PETG profile and updated the filament diameter to match what I measured on the actual roll of material and updated the extrusion multiplier to get exactly a .45mm wall.  You can check this by printing a 20x20mm cube in vase mode.</p><p>One other thing to update is the volumetric flow rate for the brand of petg your using, they are not all the same.  For example Hatchbox PETG volumetric flow rate is 2x that of Polymaker Polylite PETG.</p><p>With those updated settings on the Prusament PETG profile my prints turn out as good or better than my PLA prints. </p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/input-shaper-mini/">Input Shaper (MINI)</category>                        <dc:creator>Brian</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/input-shaper-mini/print-quality-petg-with-is/#post-698188</guid>
                        <link>https://forum.prusa3d.com/forum/input-shaper-mini/print-quality-petg-with-is/#post-698180</link>
                        <pubDate>Wed, 07 Feb 2024 21:02:40 +0000</pubDate>
                        <description><![CDATA[Do you mean &quot;lift&quot; or &quot;retraction&quot;?Because my retraction is way more than 0.8...]]></description>
                        <content:encoded><![CDATA[<p>Do you mean "lift" or "retraction"?</p><p>Because my retraction is way more than 0.8...</p><p> </p><p><a href="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2024/02/603862ce-prusa_mini_lift_retraction.png"><img class="alignnone size-medium wp-image-163485" src="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2024/02/603862ce-prusa_mini_lift_retraction-600x437.png" alt="" width="600" height="437" /></a></p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/input-shaper-mini/">Input Shaper (MINI)</category>                        <dc:creator>ToddG</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/input-shaper-mini/print-quality-petg-with-is/#post-698180</guid>
                        <link>https://forum.prusa3d.com/forum/input-shaper-mini/print-quality-petg-with-is/#post-697562</link>
                        <pubDate>Sun, 04 Feb 2024 10:43:06 +0000</pubDate>
                        <description><![CDATA[You might want to play a bit with the retraction setting, that can fix similar issues sometimes. I had a similar situation and reducing the retraction from 0.8mm to 0.2mm fixed it then - ymm...]]></description>
                        <content:encoded><![CDATA[<p>You might want to play a bit with the retraction setting, that can fix similar issues sometimes. I had a similar situation and reducing the retraction from 0.8mm to 0.2mm fixed it then - ymmv.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/input-shaper-mini/print-quality-petg-with-is/#post-697562</guid>
                        <link>https://forum.prusa3d.com/forum/input-shaper-mini/print-quality-petg-with-is/#post-697508</link>
                        <pubDate>Sat, 03 Feb 2024 21:35:58 +0000</pubDate>
                        <description><![CDATA[both of those spots are after a seam.however other seams on the prints are fine.screenshot of slicer with seam, also screenshot of layers settings.
I have it set to aligned, fill gaps, arac...]]></description>
                        <content:encoded><![CDATA[<p>both of those spots are after a seam.<br />however other seams on the prints are fine.<br />screenshot of slicer with seam, also screenshot of layers settings.</p>
<p>I have it set to aligned, fill gaps, arachne</p>
<div id="wpfa-163306" class="wpforo-attached-file"><a class="wpforo-default-attachment" title="c058b47c-prusa_mini_print_settings_layers_perimeters_screenshot-2024-02-03-133213.png" href="//storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/wpforo/default_attachments/1706996159-c058b47c-prusa_mini_print_settings_layers_perimeters_screenshot-2024-02-03-133213.png" target="_blank" rel="noopener"> c058b47c-prusa_mini_print_settings_layers_perimeters_screenshot-2024-02-03-133213.png</a></div>
<div id="wpfa-163307" class="wpforo-attached-file"><a class="wpforo-default-attachment" href="//storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/wpforo/default_attachments/1706996185-586318ea-prusamini_sliced_seam_screenshot-2024-02-03-132923.png" target="_blank" title="586318ea-prusamini_sliced_seam_screenshot-2024-02-03-132923.png"><i class="fas fa-paperclip"></i>&nbsp;586318ea-prusamini_sliced_seam_screenshot-2024-02-03-132923.png</a></div>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/input-shaper-mini/print-quality-petg-with-is/#post-697508</guid>
                        <link>https://forum.prusa3d.com/forum/input-shaper-mini/print-quality-petg-with-is/#post-697507</link>
                        <pubDate>Sat, 03 Feb 2024 21:21:11 +0000</pubDate>
                        <description><![CDATA[Posted by: @brian-12 I was going to suggest looking at the tool paths in the slicer to see if that tells you anything.  I have had to up the temp with PETG 10 degrees with IS, but your probl...]]></description>
                        <content:encoded><![CDATA[<p> </p><blockquote data-userid="521161" data-postid="697505" data-mention="brian-12"><div class="wpforo-post-quote-author"><strong> Posted by: @brian-12 </strong></div><p>I was going to suggest looking at the tool paths in the slicer to see if that tells you anything.  </p><p>I have had to up the temp with PETG 10 degrees with IS, but your problem seemed only on 1 area and not random throughout the print. </p></blockquote><p>Yes, you can turn on visibility of seams, retractions, etc. in the slicer and see if the anomalies line up with anything.</p><p>Regards,</p><p>Mark</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/input-shaper-mini/">Input Shaper (MINI)</category>                        <dc:creator>mark</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/input-shaper-mini/print-quality-petg-with-is/#post-697507</guid>
                        <link>https://forum.prusa3d.com/forum/input-shaper-mini/print-quality-petg-with-is/#post-697505</link>
                        <pubDate>Sat, 03 Feb 2024 21:16:04 +0000</pubDate>
                        <description><![CDATA[I was going to suggest looking at the tool paths in the slicer to see if that tells you anything.  I have had to up the temp with PETG 10 degrees with IS, but your problem seemed only on 1 a...]]></description>
                        <content:encoded><![CDATA[<p>I was going to suggest looking at the tool paths in the slicer to see if that tells you anything.  </p><p>I have had to up the temp with PETG 10 degrees with IS, but your problem seemed only on 1 area and not random throughout the print. </p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/input-shaper-mini/print-quality-petg-with-is/#post-697505</guid>
                        <link>https://forum.prusa3d.com/forum/input-shaper-mini/print-quality-petg-with-is/#post-697503</link>
                        <pubDate>Sat, 03 Feb 2024 20:54:08 +0000</pubDate>
                        <description><![CDATA[Posted by: @toddg No crashes, everything printed and completed.Only issue is those two side walls, the rest of the boxes/prints look great.Does the problems follow the seams? Try different s...]]></description>
                        <content:encoded><![CDATA[<blockquote data-userid="260332" data-postid="697500" data-mention="toddg"><div class="wpforo-post-quote-author"><strong> Posted by: @toddg </strong></div><p>No crashes, everything printed and completed.</p><p>Only issue is those two side walls, the rest of the boxes/prints look great.</p></blockquote><p>Does the problems follow the seams? Try different seam settings. There are issues with seams in IS.</p><p>What is this setting currently?</p><p>Print Settings | Layers and Perimeters | Advanced | Seam Position</p><p>Regards,</p><p>Mark</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/input-shaper-mini/print-quality-petg-with-is/#post-697503</guid>
                        <link>https://forum.prusa3d.com/forum/input-shaper-mini/print-quality-petg-with-is/#post-697500</link>
                        <pubDate>Sat, 03 Feb 2024 20:45:25 +0000</pubDate>
                        <description><![CDATA[No crashes, everything printed and completed.Only issue is those two side walls, the rest of the boxes/prints look great.]]></description>
                        <content:encoded><![CDATA[<p>No crashes, everything printed and completed.</p><p>Only issue is those two side walls, the rest of the boxes/prints look great.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/input-shaper-mini/print-quality-petg-with-is/#post-697500</guid>
