No input shaper option for mini+??
CELO
 CELO
(@celo)
Hi all, I was hoping someone could help. I have a Prusa mini+ at home, where I only updated the firmware and slicer (5.1.2 and 2.7.1) about a month ago, so I could use the input shaper, and it works great!
We also have a Prusa mini+ at work, and today I have updated the printer firmware to 5.1.2, and have been helping my colleagues update their Prusa slicer to 2.7.1. For some reason, when they try to run the configuration wizard, they have no option for selecting input shaper under FFF for the mini+. The only one that has the input shaper option available is the Mk4.
Why is this? I have it on my Prusa slicer? We have double checked that everything is up to date, but cannot see an option to select input shaper for the mini+.
Any help would be most appreciated.
Opublikowany : 06/02/2024 8:40 am
_KaszpiR_
(@_kaszpir_)
RE: No input shaper option for mini+??
press in the menu Configuration > Check for Configuration Updates and try to run Configuration Wizard again
Opublikowany : 07/02/2024 11:30 am
1 ludzie polubili
Misza
(@misza)
Hi, I have te same problem - no input shaper profile in Prusasliser... Checking for Configuration Updates does't help at all...
Opublikowany : 21/02/2024 9:40 pm
Where are you looking?
this is in Prusa 2.7.1
Joan
Opublikowany : 21/02/2024 9:51 pm
Misza
(@misza)
Ok, I looked in the configuration wizard, but the IS profile wasn't there. I also reinstalled PrusaSlicer, but that didn't help either. What did help was manually removing the Prusa folder from: C:/Users/username/AppData/Roaming/PrusaSlicer. After that I just started PrusaSlicer and the Mini IS profile appeared in the wizard... strange. But it works fine now.
Opublikowany : 21/02/2024 10:07 pm
Good Result
Opublikowany : 21/02/2024 10:23 pm
