					                		Is this firmware compatible with a Revo Mini hot end? - Input Shaper (MINI)                                    </title>
                <link>https://forum.prusa3d.com/forum/input-shaper-mini/is-this-firmware-compatible-with-a-revo-mini-hot-end/</link>
                <lastBuildDate>Sat, 06 Jun 2026 14:39:52 +0000</lastBuildDate>
                        <title>RE: Is this firmware compatible with a Revo Mini hot end?</title>
                        <link>https://forum.prusa3d.com/forum/input-shaper-mini/is-this-firmware-compatible-with-a-revo-mini-hot-end/#post-674773</link>
                        <pubDate>Wed, 20 Sep 2023 07:16:28 +0000</pubDate>
                        <description><![CDATA[I tested it on my MINI+ with Revo Hotend, and it works excellent for models I sliced myself (0.4mm Nozzle)But The provided 16-minute bonkers benchy looks very ugly. A benchy following the sp...]]></description>
                        <content:encoded><![CDATA[<p>I tested it on my MINI+ with Revo Hotend, and it works excellent for models I sliced myself (0.4mm Nozzle)</p><p>But The provided 16-minute bonkers benchy looks very ugly. A benchy following the speedboot rules looks almost perfect and took just 46 minutes to print. </p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/input-shaper-mini/">Input Shaper (MINI)</category>                        <dc:creator>TheBavarianModelMaker</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/input-shaper-mini/is-this-firmware-compatible-with-a-revo-mini-hot-end/#post-674773</guid>
                        <link>https://forum.prusa3d.com/forum/input-shaper-mini/is-this-firmware-compatible-with-a-revo-mini-hot-end/#post-674621</link>
                        <pubDate>Tue, 19 Sep 2023 14:38:14 +0000</pubDate>
                        <description><![CDATA[Yes, some of ppl with Revo confirmed that it works pretty well, even with 0.6 mm nozzle with 0.4 mm profile 😋 but it still in Alpha, so we can still expected some fine tuning.]]></description>
                        <content:encoded><![CDATA[<p>Yes, some of ppl with Revo confirmed that it works pretty well, even with 0.6 mm nozzle with 0.4 mm profile 😋 but it still in Alpha, so we can still expected some fine tuning.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/input-shaper-mini/">Input Shaper (MINI)</category>                        <dc:creator>Neolker</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/input-shaper-mini/is-this-firmware-compatible-with-a-revo-mini-hot-end/#post-674621</guid>
                        <link>https://forum.prusa3d.com/forum/input-shaper-mini/is-this-firmware-compatible-with-a-revo-mini-hot-end/#post-674597</link>
                        <pubDate>Tue, 19 Sep 2023 13:38:42 +0000</pubDate>
                        <description><![CDATA[Wouldn&#039;t the input shaper profile need to change if the hotend weight changes? Wouldn&#039;t a Mini with mods affecting weight, movement, rigidity (aka the Prusa Mini Base) change its standard re...]]></description>
                        <content:encoded><![CDATA[<p>Wouldn't the input shaper profile need to change if the hotend weight changes? Wouldn't a Mini with mods affecting weight, movement, rigidity (aka the Prusa Mini Base) change its standard resonance that input shaper compensates for? </p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/input-shaper-mini/">Input Shaper (MINI)</category>                        <dc:creator>Sugarlumpz</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/input-shaper-mini/is-this-firmware-compatible-with-a-revo-mini-hot-end/#post-674597</guid>
                        <link>https://forum.prusa3d.com/forum/input-shaper-mini/is-this-firmware-compatible-with-a-revo-mini-hot-end/#post-674509</link>
                        <pubDate>Tue, 19 Sep 2023 04:22:53 +0000</pubDate>
                        <description><![CDATA[You didn&#039;t change anything even on stock firmware after installing Revo, it&#039;s made to be a drop-in replacement, don&#039;t worry about compatibility c:So excited to see this update this early]]></description>
                        <content:encoded><![CDATA[<p>You didn't change anything even on stock firmware after installing Revo, it's made to be a drop-in replacement, don't worry about compatibility c:<br /><br />So excited to see this update this early</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/input-shaper-mini/">Input Shaper (MINI)</category>                        <dc:creator>Clares</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/input-shaper-mini/is-this-firmware-compatible-with-a-revo-mini-hot-end/#post-674509</guid>
                        <link>https://forum.prusa3d.com/forum/input-shaper-mini/is-this-firmware-compatible-with-a-revo-mini-hot-end/#post-674505</link>
                        <pubDate>Tue, 19 Sep 2023 02:51:33 +0000</pubDate>
                        <description><![CDATA[Loaded it on mine with a revo mini, did the 17 miniute benchy and was successful. Doing some gridfinity boxes as a another test now and seems to be working out really well.]]></description>
                        <content:encoded><![CDATA[<p>Loaded it on mine with a revo mini, did the 17 miniute benchy and was successful. Doing some gridfinity boxes as a another test now and seems to be working out really well.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/input-shaper-mini/">Input Shaper (MINI)</category>                        <dc:creator>MetroKitten</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/input-shaper-mini/is-this-firmware-compatible-with-a-revo-mini-hot-end/#post-674505</guid>
                        <title>Is this firmware compatible with a Revo Mini hot end?</title>
                        <link>https://forum.prusa3d.com/forum/input-shaper-mini/is-this-firmware-compatible-with-a-revo-mini-hot-end/#post-674479</link>
                        <pubDate>Tue, 19 Sep 2023 00:20:52 +0000</pubDate>
                        <description><![CDATA[Curious if I can use this firmware with my modified printer.]]></description>
                        <content:encoded><![CDATA[<p>Curious if I can use this firmware with my modified printer. </p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/input-shaper-mini/">Input Shaper (MINI)</category>                        <dc:creator>kevman</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/input-shaper-mini/is-this-firmware-compatible-with-a-revo-mini-hot-end/#post-674479</guid>
