How do I turn *off* the input shaper?
There are no longer any presets that *don't* have the input shaper, and I'm having serious quality issues and would just like to disable it. How do I go about that?
RE: How do I turn *off* the input shaper?
The only way I'm aware to disable it is from the printer menu. I highly doubt it's at all related to the quality issues your having. All input shaping does is compensate for unwanted movements related to the kinematics of your printer. If you want to slow it down I recommend doing that in the slicer by reducing the volumetric flow rate in the filament settings to a level that you deem acceptable.
Maybe also attach some pictures of the issues your having.
There are unfortunately a lot of variables.
My MINI was broken from last July though about 2 weeks ago (broken y-axis stepper motor, just took me a while to find the time to disassemble/reassemble it.)
When I got it back online, I upgraded the PrusaSlicer from 2.6.?? to 2.9.0, and then almost immediately to 2.9.1. At some point it downloaded a bunch of new printer definitions which included the Input Shaper designation. Shortly thereafter the bowden tube failed, and my attempt to build a new one went sideways and the replacement ended up 2x as long as it should. I ordered a replacement from Prague, but it only arrived today, and I haven't had a chance to replace it yet.
Several things changed about about my sliced/generated gcode since I got the printing running again, even before the problems with the bowden tube. The temperature ranges for "Generic PLA" went from 215/210 to 230/225 C, the print speed went *way* up, and the quality went down considerably. (also the purge strip at the beginning of the print went from right->left to left->right, but I doubt that's an issue, just a sign the stuff has changed.) The problem is that I'm having excessive stringing and overextrusion, the precision of printing has gotten a lot sloppier. I've seen a lot of people on here complaining about similar problems since the PrusaSlicer 2.9.x upgrades and the 5.x firmware release, and a number seem to implicate the Input Shaper changes, though I guess it *might* be the speed increase that came along with it.
The overextrusion/stringing might be due to the wacky bowden tube, so I've increased the retraction from 2.5mm to 5.0mm, but that hasn't changed the behavior. What I have noticed is that the old gcode sliced before everything changed is still printing well, it's only the stuff sliced since the changes that seems to have trouble.So I'd like to see if I can back out those changes in the slicer configuration, but it isn't obvious how to do that, other than just re-install the old packages (not even sure that would work, since the profiles that would be downloaded from prusa3d.com would still have the IS configuration? The profiles I can find no longer have a option that *doesn't* mention the input shaper, and I'd like to back that out as well.
I'll try to get some apples to apples comparison pictures tomorrow.
Here's an example
The ring on the left is from the old gcode/slicer, and the newer gcode/slicer is on the right. Sure, it prints twice as fast but it looks awful.
I've sliced one with slower speeds (x&y feed rates), and I'll see if that helps.
You can create a new profile with Print Settings > Speed cut in half.
Here's an example
Agreed, looks worse. What printing profile are you using?
Things like belt tension can also cause things like this.
Do you mean this one? It's at the bottom of the configuration wizard for Prusa machines.
That was exactly what I was looking for..... never thought to scroll all the way to the bottom. Thanks much!
I’m having similar issues as well. Just got my mini last month and new to the game. Didn’t dawn on me to use the “legacy printer” instead of the newest latest and greatest option.
of course in the first week alone did the slice engineering copperhead heat end & Bondtech ifs extruder … still trying to sort out those settings.
Thanks for this. I also missed it. "Input shaper" on my mini is solving problems I did not have (time, puhleeze) while introducing worse prints and the occasional very bad print from the fast retraction shifting the entire print somehow so above a certain level everything's off by half a mm or so. Gotta redo the wizard now.
