5.1.0-alpha1 Firmware for Original Prusa MINI/MINI+ with Input Shaper and Prusa Connect!
the MINI and MINI+ just got a major firmware upgrade: Input Shaper, Pressure Advance, Prusa Connect and many more...
Currently, this is an alpha release dedicated only to experienced users. See the full release notes, including firmware, G-code and instructions: https://github.com/prusa3d/Prusa-Firmware-Buddy/releases/tag/v5.1.0-alpha1
Who will be the first to print the BonkersBenchy? 😉
RE: 5.1.0-alpha1 Firmware for Original Prusa MINI/MINI+ with Input Shaper and Prusa Connect!
Nice plans, but for me, it doesn't work, if I select any file, with or without IS, it frozes and goes to BSOD. Dump here
I am impressed! Especially considering I forgot to swap my nozzle from 0.6 to 0.4.
I have never seen my Mini move so quickly. No ringing on this print either.
Oh Exciting,
Can't wait to give this a go........
I was just watching a print thinking that I wish the Mini could move faster like the MK4 & Bambu Labs with input shaping.
Now if this works well I will not feel like I'm missing out on anything.
Can I use this if I have a Revo hotend on my mini ?
After installing the firmware my hot end would just bang until "error Homing" if you have this happen to you , POWER OFF the entire mini via switch (not reset) and turn back on . It will home fine 1 time, then back to error.
So Turn Off , Hit Print and you get 1 home and print works . after that print you need to do the whole power off thing again.
I did.
Thanks ! Did you have to do anything beyond updating the firmware ? calibration etc ?
I did.
I just updated the new firmware.
Welp...getting a failed to home x axis..it keeps banging the hjot end into the right and then reboots.
Issue reported here
I'm currently testing this, and the time reduction is quite impressive. It's really great to see Prusa not forgetting about this little machine. I've been eagerly awaiting news like this since the MK4. I wondered if there was a possibility to implement something similar on the Mini, as they shared a lot in common 😋
I got successful print off the 5.1.0-alpha1 (sliced with the new Mini Alpha profile from PrusaSlice 2.6.1) before I'm stuck with a failed to home x axis error (bangs the hotend into the right repeatedly). After it beeps and shows the error screen/QRCode, I can click the button and it reboots. Took a hard power cycle (toggled unit off, removed power for 1 minute, reinserted power, turned unit back on) before I could at least get the filament unloaded.
The error links to https://prusa.io/12304 (but that only takes you to the Prusa3D homepage for now, I presume that error hasn't been officially added yet)
There's an additional code below that reads O0H8ABOS
Prusa Mini Error Code for Homing Error X: https://prusa.io/12304
Wasn't able to do much more afterwards. I'll attempt to troubleshoot some more, but a simple test print using a filament swatch with test added via PrusaSlicer turned out fairly decent, and half the time (17 minutes vs 34 minutes prior to the Alpha firmware).
Simple Filament swatch comparison Prusa MK3 (35-37minutes, top model) vs Mini 5.1.0-alpha1 (17 minutes, bottom model)
My post is still waiting moderation for the work around I found . Power off your printer with the switch , waif 10 sec power it on . you can now home 1 TIME, and then the cycle starts over again.
so I Power off , power on , hit print = homes and prints just fine . after Print you have to power cycle again.
Hope they fix it , I have 14 minis but I only tried the update on 1 of them .
For those with homing issue: tighten up your x axis belt, that helped me.
I wonder why some are getting the homing crash yet others not - i need to wait till they bring back Octoprint compatibility
I printed mine from Octoprint
