[Solved] wrong infill in object in PrusaSlicer
czolli
(@czolli)
hello team,
I would like to print an adapter for the extractor hood.
Large pipe connection -> taper -> small pipe connection
There are warnings in the *.scad file, but the object looks good.
In PrusaSlicer the object also looks good, but when I slice it, the middle part becomes a solid.
What am I doing wrong?
scad-file:
http://www.blaubeerkanu.de/AbzugshauenAdapter120auf100.scad
stl-file:
http://www.bblaubeerkanu.de/AbzugshauenAdapter120auf100.stl
Best Answer by czolli:
I sliced the object in Cura, saved it as a project and opened it in PrusaSlicer.
Now all is well 😉
Posted : 06/09/2021 3:31 pm
czolli
(@czolli)
sorry: link correction
stl-file:
http://www.blaubeerkanu.de/AbzugshauenAdapter120auf100.stl
Posted : 06/09/2021 4:00 pm
czolli
(@czolli)
solved
Now all is well 😉
Posted : 06/09/2021 7:04 pm
Not sure I know what you mean by "middle part becomes a solid", but I downloaded the scad file, rendered it, and opened the STL in Prusaslicer, I see nothing wrong at all. I then checked your STL, same thing. Your contraption looks just like the SCAD design in Prusaslicer after slicing.
OpenSCAD 2021.01
Prusaslicer 2.4 Alpha 1
Posted : 06/09/2021 7:47 pm
czolli
(@czolli)
apparently a software problem
Thank you fuchsr for your efforts.
When I slice the file, I get the following:
It should be open in the middle like in edit mode....
OpenSCAD version 2021.01
PrusaSlicer 2.3.0+
Posted : 06/09/2021 9:00 pm
czolli
(@czolli)
RE: definitely a software problem 🙁
I have now installed the PrusaSlicer 2.3.3 version.
The problem no longer exists.
This post was modified 5 years ago by czolli
Posted : 06/09/2021 9:25 pm
