Visible Seams
Majed
(@majed)
Visible Seams
I've printed this part on the MK3S (default 0.3mm layer height) and it was clean, the seams weren't appearing. Printing on the MINI (default 0.25mm layer height), the seams are visible as shown in the picture.
Seam position is set to nearest (default).
I've tried changing the k-factor to different values, the result was the same.
I've printed once at 240C, and once at 245C, same result on both prints.
I'm using Filatech White PETG, and it have been dried. I've used the exact same roll on the MK3S and it gave me good result.
For reference, the size of this part is 20x20x25 mm.
How can I remove or reduce the visibility of these seams?
Thank you.
Ce sujet a été modifié il y a 4 years par Majed
Publié : 21/02/2022 2:17 pm
