Variable Infill
prntmkr
(@prntmkr)
Variable Infill
Hi all,
how do I print a variable infill density?
Example: I want to print something that has got a hole in it so I can mount it on a wall with a screw. A few milimeters around that hole I would like to have an infill density of 100% to make sure the screw holds well, the rest of the object may have 30% infill density.
Any clue?
Posted : 14/12/2020 6:55 pm
right click on model in prusa slicer 3d editor view,
choose modifier, choose cylinder,
resize and place cylinder where you want to change the model
select layers and perimeters on the modifier, and change as desired
re slice and you should be good to go!
Posted : 14/12/2020 7:45 pm
6 people liked
prntmkr
(@prntmkr)
RE: Variable Infill
@joantabb
Thank you very much for your swift reply!
This for sure works very fine.
Posted : 14/12/2020 9:04 pm
