TPU flex printing issue nozzle stucken in print mid print fail
Dr_Froggy_rD
(@dr_froggy_rd)
Hi there ,
I had a few times the same issue with my pridsa mini. and up to now was unable to get it work properly. I looked in the forum very quick for any hints but was not successful ( even an ia search was unsuccessful for this)
My print starts and print at least 1 layer then at some point. it is stucked mid print. the nozlle let a huge amounts of material flow out of the nozzle which blocks the  nozzle in the print. causing error 12207 which is not minbed error as when I immediatly stop / restart theprinter the temperature of the nozzle is at 200C as the bed. I do not uderstand that the error shows  minbed temperature at this point  when it is in fact only anozzle stucked in print.
this error never happens with PLA only with tpu.
  I did some great print with flexible filament in the past but I cannot recall how I did that... Just need some hints thank you.
Publié : 03/12/2025 8:57 am
Dr_Froggy_rD
(@dr_froggy_rd)
So a small edit: the edit fnction did not work.
So I solved this issue in the past by increasing temperature to 244°C which helped alot during printing a complete object. although the risk is nozzle clogging at some point
Best Regards,
frogfrog
Ce message a été modifié il y a 8 hours 3 fois par Dr_Froggy_rD
Publié : 03/12/2025 9:40 am
