Supports keep failing
M8Harry
(@m8harry)
Hi all.
Im having a problem with supports. They keep breaking off the build plate. The model is perfectly fine its the supports that are failing.
Is there any way to put a raft under supports of are there any settings in PrusaSlicer I should have checked or unchecked to help anchor them down better. I have tried painters tape and even that failed in 1 section where the support was too small to tape down.
using 0.05 layer height and default settings for supports
Este debate ha sido modificado el hace 6 years por M8Harry
Respect the fact everyone is entitled to have an opinion, you dont have to like it or hate it, just accept its theirs and not yours and you will be ok!
Respondido : 13/01/2020 5:59 pm
Petzon
(@petzon)
RE: Supports keep failing
You will find raft under Print settings/Support material, see attached
Respondido : 18/01/2020 3:00 pm
M8Harry
(@m8harry)
@martin-p75
I was hoping I could raft the supports only and not the whole print.
Respondido : 18/01/2020 9:41 pm
Mary Tillios
(@mary-tillios)
Did the setting help you? You can solve the problem with synthetic materials, but I'm not sure what will help.
Respondido : 12/03/2020 12:57 pm
