Some wierd groves on Funnel print
Bazim
(@bazim)
Hello, can you tell me what are these wierd groves on my Funnel print?
Material: PLA
Printer: PRUSA MINI+
Model:  https://www.printables.com/cs/model/26038-funnel
Infill: 0%
Perimeters: 2
Resolution: 0,2 mm QUALITY
On Reddit someone told me that is a overextrusion, but I am starting to read about it. I really do not know what it is at the moment.
Thank you for your help.
Postato : 12/06/2022 5:14 pm
Utenti
RE: Some wierd groves on Funnel print
Are you sure you are not having an extrusion issue?  It could also be wet filament.
You could upload the 3MF file.
Postato : 12/06/2022 5:49 pm
Bazim
(@bazim)
I just download the .stl file, and set 0,2mm QUALITY profile and 0% infill. No more changes. On the model page there is someones print also, and maybe I see this groves on it too, but I am not sure, that is the reason why I spammed it here. Calling for help if its normal or something is not right with my printer.
Last issue I had was no extrusion at all, because my filament was stuck in the extruder. So the customer support help me clean that and check the PTFE tube inside the thing where fans and hotend are.
Postato : 12/06/2022 6:06 pm
More likely than not this is caused by gap infill in the slope of the funnel. You can probably improve quality by adjusting your extrusion width to get rid of the gap infill. But without the 3mf hard to say.
Postato : 12/06/2022 7:21 pm
1 persone hanno apprezzato
