[Solved] Smoother top layers.
Adam95
(@adam95)
I have been trying to get a smoother top layer on this for a while now and dont seem to be getting anywhere, i think its because the top layers are on a slope and not level. The one on the left is with a 0.1 layer height and the one on the right is .15 with ironing enabled, any advice would be appreciated.
Thanks.
Best Answer by BogdanH:
...i think its because the top layers are on a slope and not level.
-you already know the reason. And there's no solution for that.. except sanding and coating afterwards. Depending on filament type, you can also try bathing in acetone vapor (to smooth the surface).
Posted : 25/01/2022 7:04 am
BogdanH
(@bogdanh)
RE: Smoother top layers.
[Mini+] [MK3S+BEAR]
Posted : 25/01/2022 8:55 am
Adam95
(@adam95)
okay no problem i thought that would be the reason. Thanks for the reply 👍 .
Posted : 25/01/2022 11:18 am
