PrusaSlicer : error message line empty
Hello,
I am beginner in 3D printing 🙂
I would like to print this little pyramid with my Prusa Mini+ :
https://www.thingiverse.com/thing:3047729/files
File : Tz_templetrack.stl
When, I select generate the GCode, error message is present : empty line is present
I would like to print it larger with a size of X = 20mm
And I can see empty line with the zoom+
So, do you know how to remove the empty line ?
I try to repaire the stl file with the option in the menu mais error still present.
For information number 1 : if I don't change the size of the pyramide, no error message
For information number 2 : quality 0,15 and with fill 15%
Thanks for your help
Seb
This topic was modified 5 years ago 3 times by Seb38
Posted : 07/07/2021 4:53 pm
