Printing Thin Walls
Alex Ardeleanu
(@alex-ardeleanu)
Printing Thin Walls
Hello!
I am trying to print a clip+diffuser for a LED light, hence the need for a thin portion of the print. The part in the picture is based on a symmetrical design, however the printing problem only arises at one side of the thin portion (0.4mm thickness), while the other end prints as expected, therefore I think the issue could be resolved by means of software settings.  I have tried 3 iterations of the print, all upright: wall parallel to the y-axis with 0.25mm and 0.20mm layer height, and perpendicular to the y-axis 0.20mm layer height. All runs led to the gaps on only one side of the wall.
I am printing on a Prusa MINI, 0.4mm nozzle, with eSUN PLA.
Thanks in advance for the help!
Best Answer by JoanTabb:
you have not  included a project file for us to look at so this is a total guess.
you say the thin portion of the design is 0.4mm thick and you are using a 0.4mm nozzle...
I suspect you are also using a default Prusa Mini profile, with the default extrusion width settings
your thin print will only be using an external perimeter for the thin section of the print.
it ia probable that your extrusion width setting is wider than the thin section of the model,  reducing the external perimeters extrusion width, to 0.4mm may be all that you need to do
alternatives,
1, in Prusa slicer, unlock the 'Scale Factors' in the Object manipulation window of Prusa slicer, then adjust the size of the model, in the direction that would thicken the thin panel,   the down side of this, may be that the retaining slot also becomes loose
2, In prusa slicer  increase the 'XY Size Compensation' value to perhaps 0.025mm   to artificially thicken the thin panel of the model
the down side of this option is that it may make the retaining slot too tight
3, Revise the original 3D model to have a slightly thicker , thin panel
A combination of options 1 and 2, may both thicken the panel and restore the retaining slot fit to reasonable values
Good luck,
Joan
Opublikowany : 19/01/2025 8:12 am
RE: Printing Thin Walls
alternatives,
Good luck,
Joan
Opublikowany : 19/01/2025 10:21 am
1 ludzie polubili
@joantabb spotted the issue - a single perimeter under extruding leaves no room for the slicer to hide/disguise construction constraints.
Instead of printing white which has a lot of blocking pigment consider redesigning at two extrusions thick and printing with clear filament.  Unless you take steps to prevent it the 'clear' print will look milky/translucent with a useful diffusion effect.
Opublikowany : 19/01/2025 11:25 am
1 ludzie polubili
Alex Ardeleanu
(@alex-ardeleanu)
Thanks for the tips. The wall thickness smaller than the size of the nozzle was also under my suspicion. However, as it appeared in the picture, the artefacts/gaps show up only on one side of the wall, while the other edge is spotless. This inconsistent behaviour seemed strange to me.
In the meantime, I tried it with a thickness of 0.46 as well with the same result of gaps only on one side of the wall.
I can't seem to be able to attach the stl file to the reply, so that you can inspect it.
For the current project, I managed to print the parts laying down, by reducing the overhang of the clips on top.
Opublikowany : 19/01/2025 12:06 pm
Alex Ardeleanu
(@alex-ardeleanu)
Thanks @diem as well, for the observation about the colour. White is indeed not translucent enough, I will reprint the parts in clear PLA once I acquire some.
Opublikowany : 19/01/2025 12:13 pm
Hi Akex,
A Project file is better than the STL,
Prusa slicer project files include the settings for the slicer as well as the  STL, in the orientation that you propose to print the model
which helps us make more accurate suggestions.
to save a project file, drop down the Prusa Slicer 'File' Menu, and choose 'Save Project as'
save the file to a known location with a recognisable file name, then ZIP Compress the project file,
then you can attach the Zipped file to the next post.
STL Files also need to be Zipped, or the forum will silently drop the files.
Opublikowany : 19/01/2025 12:54 pm
Alex Ardeleanu
(@alex-ardeleanu)
Thanks again for the tips.
Here is the archived project file: clip_light
These were the two orientations I was talking about, now with the 0.46mm thick walls. Both produce gaps only on one side of the wall, as can be seen in the image of the initial post. This led me to think that the issue might be slicer-based, not necessarily a limitation of the printer.
In the end, printing the part laying down works better for this particular project, but I think getting some insight into the issue might still be relevant for future endeavours.
Opublikowany : 19/01/2025 2:40 pm
I had a go at printing these items on my Mk3.9 printer using Prusa PETG white
this was the first print on Satin Powder coated Sheet
as you can see, the left hand part had a slight hole at the bottom
the second pair, I printed external perimeters first
the top two were the first pair, the bottom two, were the ones with external perimeters printed first
Opublikowany : 19/01/2025 6:44 pm
