Perimeter settings in slicer ?
Sfbrain
(@sfbrain)
Hi Guys,
I am developing a profile in NYLON for my Mini
The model i am working with needs to hold water when printed and i was wondering if there is a setting in the slicer to vary the overlap of perimeters in the model ?
I have found the setting for the overlap of the infil and the perimeters but wondered if there is a setting for the overlap of multiple perimeters ?
Thanks
Steve B
Posted : 05/12/2020 10:38 am
Sfbrain
(@sfbrain)
RE: Perimeter settings in slicer ?
@diem
Hi Diem,
Thanks for this, but i am just a beginner and have not played with the Gcodes before.
I found the place the article refers to, there is this already there ...
M900 K{if printer_notes=~/.*PRINTER_MODEL_MINI.*/ and nozzle_diameter[0]==0.6}0.12{elsif printer_notes=~/.*PRINTER_MODEL_MINI.*/}0.2{elsif nozzle_diameter[0]==0.6}0.04{else}0.08{endif} ; Filament gcode LA 1.5
{if printer_notes=~/.*PRINTER_MODEL_MINI.*/};{elsif printer_notes=~/.*PRINTER_HAS_BOWDEN.*/}M900 K200{elsif nozzle_diameter[0]==0.6}M900 K24{else}M900 K45{endif} ; Filament gcode LA 1.0
Should i replace the above with M900 K0 as the article suggests ??
Or add it at the end ??
Cheers
Steve
Posted : 06/12/2020 7:28 pm
Make a backup copy of your filament profile (so you can roll back if you mess up), and replace the whole of that big conditional with M900 K0
That's all ...
Posted : 07/12/2020 5:35 pm
Sfbrain
(@sfbrain)
@diem
Hi Diem,
Thanks, i tried it today and my print is currently holding water
Looks like it worked a treat, thanks again
Steve
Posted : 07/12/2020 6:38 pm
... just take care not to use that profile for general, non waterproof, prints or you'll have problems.
Posted : 07/12/2020 7:34 pm
