Opinion on my print quality
Krope
(@krope)
Hello, can i get an Opinion from you guys for my Print Quality? For me there is Somthing wrong , i try out diferent things put nothings seems to work.
I updated my mini with the Bondtech Feeder and the Bondtech Heatbreak....
I use the Standart Settings, 0.4 Nozzle 0,2 Layer High, PLA from Extrudr
thank you!
This topic was modified 6 years ago by Krope
Posted : 29/06/2020 5:46 pm
John Doe
(@john-doe-3)
RE: Opinion on my print quality
You could send a query to Bondtech, on what would they recommend to change.
I see with my little eye more a problem on parts, where the nozzle must change the way, like edges, or start a new was from a corner. Maybe more of an issue of slow retraction out. On some of the pictures I see like belts would be a bit loose.
Posted : 01/07/2020 6:36 am
Oxygen
(@oxygen)
a quick question: have you added this: (from Bondtech Feeder install manual )
add M92 E415 to the start G-code in the slicer before the ; intro line.
Stock MK4S with FW 6.2.6
Posted : 01/07/2020 7:17 am
Krope
(@krope)
@oxygen
Hy, yes i have added the Code from the Feder and also from the Heatbreak....
Posted : 01/07/2020 8:11 pm
Oxygen
(@oxygen)
Then you should contact the Bondtech people to see if they can assist you.
Posted : 01/07/2020 8:27 pm
Krope
(@krope)
Hello!
the answer comes a little late but I know better late than never, Bondtech helped me but I had to test a little to get a good result, here is a picture of the settings that work for me now if someone has these problems too.
Posted : 06/08/2020 11:46 pm
SS220
(@ss220)
Hopefully you will print and post a new benchy so we can all see the difference!
Posted : 07/08/2020 1:05 am
atomleef
(@atomleef)
@kropexx
May I ask what they suggest to change?(from screenshot it's too much parameter to identify change for me(i am beginer) Do they reason why this happened?
thank you
Posted : 10/08/2020 6:51 am
Krope
(@krope)
Hy!
Try changing these parameters if you have problems like me:
  Retraction speed
  Distraction speed
  Retract amount before Wipe
  May you try my settings.
  I'm not perfect with the quality, but it's good, I also play with parameters to improve the quality.
I'll print a new 3D Benchy if you want to see it.
  Best Regards
This post was modified 6 years ago by Krope
Posted : 10/08/2020 9:26 pm
Charlies
(@charlies)
I´m using bondtech and heatbreak and i´m not having any issue printing TPU, PETG, and PLA.
Posted : 17/08/2020 8:39 am
