Need help to print this model
Página 2 / 2
RE: Need help to print this model
Yeah - that's pretty ugly. Looks like you need to do a serious flow calibration.
https://help.prusa3d.com/en/article/extrusion-multiplier-calibration_2257
What size nozzle are you using?
Respondido : 09/10/2020 4:16 am
Alex Hung
(@alex-hung)
Posted by: @tim-m30
O.4mm nozzle. I’ve done the cube prints for each filament I used and adjust accordingly. I think I have z height too low with multiplier too high.
For the filament I’m currently using (Raise3D) I’ve the multiplier as 1.15. The top of the cube looks reasonably filled. Still some tiny gaps between lines. Hence I think think the live z height is too low and the filament is squashed too much.
Respondido : 09/10/2020 4:21 am
I have never changed my multiplier from 1.00 .. in years. 1.15 seems very very high.
Z-height should not be a factor, unless you mean Live-Z. And with that the multiplier should NEVER be changed to adjust layer 1.
The only places you need to compensate are filament diameter (and I usually ignore that tweak), and the extruder multiplier for variation in the Bondtech gear alignment and wear.
Esta publicación ha sido modificada el hace 5 years por --
Respondido : 09/10/2020 4:27 am
Alex Hung
(@alex-hung)
Posted by: @tim-m30
You're right re extrusion multiplier value. I re-ran the first layer calibration, and set the multiplier to just 1.02 (a judgment call from previous printed cube top layer quality). And it has printed this (9.5+ hour) with only small blemishes!
I'm going to re-print the nose cone with these settings and see how that goes.
Thanks for sticking with me through all the posts and trials/errors.
Respondido : 10/10/2020 2:04 am
1 les gusta
L.R. Stevens
(@l-r-stevens)
RE: well at one time I could do this part with just a click of a box
This part as made on my Dual Extruder 3D Printer with just the click on 1 BOX doing outside with Extruder 1 and inside with
Extruder 0 . . Now i get a weird just a TINY line of White and the rest is BLUE . . What the Heck gives ? . . ..And since I have DUAL EXTRUDER's . . why is it I can't print letters ON TOP of a part ?  Slic3r will NOT let me raise the start of the letters at 10mm and print the letters on top of the part .  .Has a base of 10 mm and letters are 5mm tall . . Separate STL files
Esta publicación ha sido modificada el hace 4 years por L.R. Stevens
Respondido : 24/09/2021 4:36 pm
can you sip the project file and attach it, for us to look at please?
Respondido : 24/09/2021 5:57 pm
L.R. Stevens
(@l-r-stevens)
what is project files ?
Okay here are the files . . Can't up load STL files . . what did you mean as project  files ?  I have the STL files
Respondido : 24/09/2021 10:30 pm
Project files
If you load your STL into Prusa Slicer, set up your configuation and then click on the files menu and select Save Project As... and then save the project where ever you like, as a .3mf file...
Next, ZIP compress the file, and attach the zipped file to the post.
you can also ZIP Compress STL Files, and attach the zipfiles to posts.
Respondido : 24/09/2021 10:51 pm
L.R. Stevens
(@l-r-stevens)
here is the zipped 3mf folder
Okay here is the files you want . . Still can't upload the files and it is in a zipped file want-to.3mf tried to add an got told wrong again . . There is no ATTACH FILE icon any where !
Respondido : 25/09/2021 7:11 am
L.R. Stevens
(@l-r-stevens)
Interesting
Had to re do it
Respondido : 25/09/2021 7:14 am
I am using Windows.
When I type in the box, I Find that there is an add media click box at the top of the window
which allows me to add media to the post... as above
you can also Drag and drop an image or a file into the input screen, as I have done with the image above
I have numbered 4 parts in the image above.
Number 1 in the Add Media Dialogue tool, is where you can choose to upload a file from your computer,
After your file has uploaded (If it is an image ) you should be able to see a thumbnail for the image in the top left box, as indicated by number 2.
having loaded the file, you can click option shown by number 3, to make the image present at full size, if the person viewing the post later, clicks n the Picture
when you have finished click on the box labelled 4, to complete the insertion.
Castle time saving options
you can use the Add Media Option to add Zip files, as I have done above.  AND,
you can use the Attach file Option at the bottom of the post input box, to add files too!
In the image below I have highlighted the Add Media button  (5)
and the first Zipfile that I added (6) and the
Attach file option, (7)
I hope this information helps you attach files in the future
Attachment removed
Respondido : 25/09/2021 2:35 pm
L.R. Stevens
(@l-r-stevens)
RE: files to do project wit h
Well second time i have up loaded the files you wanted . . Says Attach and i Browsed and clicked on the file want-to.3mf  says its attached . . Mean you used old worn out Windows stuff that barley works half the Time LOL
Respondido : 25/09/2021 5:58 pm
L.R. Stevens
(@l-r-stevens)
trying again
well zipped and attached . . File-4.zip
Respondido : 25/09/2021 6:13 pm
i can't see the Zip File....
I can see a file name but it's not clickable
did you see me direct message with an email address?
Joan
Respondido : 25/09/2021 10:56 pm
Página 2 / 2
