					                		My Prusa MINI can&#039;t print small polygons - How do I print this? (Printing help)                                    </title>
                <link>https://forum.prusa3d.com/forum/how-do-i-print-this-printing-help/my-prusa-mini-cant-print-small-polygons/</link>
                <lastBuildDate>Tue, 10 Mar 2026 12:57:39 +0000</lastBuildDate>
                        <title>RE: My Prusa MINI can&#039;t print small polygons</title>
                        <link>https://forum.prusa3d.com/forum/how-do-i-print-this-printing-help/my-prusa-mini-cant-print-small-polygons/#post-705697</link>
                        <pubDate>Wed, 27 Mar 2024 22:25:41 +0000</pubDate>
                        <description><![CDATA[Does it print round objects correctly?If yes please do this calibration cube and lets start from it]]></description>
                        <content:encoded><![CDATA[<p>Does it print round objects correctly?<br />If yes please do this calibration cube and lets start from it https://www.printables.com/model/69934</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/how-do-i-print-this-printing-help/">How do I print this? (Printing help)</category>                        <dc:creator>str0gg</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/how-do-i-print-this-printing-help/my-prusa-mini-cant-print-small-polygons/#post-705697</guid>
                        <link>https://forum.prusa3d.com/forum/how-do-i-print-this-printing-help/my-prusa-mini-cant-print-small-polygons/#post-705544</link>
                        <pubDate>Tue, 26 Mar 2024 17:43:04 +0000</pubDate>
                        <description><![CDATA[I&#039;ve aligned the printer to nearly perfect position, but the problem still persists. I&#039;ve even tried lowering the printing temperature or adjusting the Z axis, but still nothing. Thank you f...]]></description>
                        <content:encoded><![CDATA[<p>I've aligned the printer to nearly perfect position, but the problem still persists. I've even tried lowering the printing temperature or adjusting the Z axis, but still nothing. Thank you for the advice</p><blockquote data-userid="517121" data-postid="705518" data-mention="str0gg"><div class="wpforo-post-quote-author"><strong> Posted by: @str0gg </strong></div><p>Your printer need to be straight in x,y,z and from picture I can tell you its not. Its paint with this printer...</p></blockquote><p> </p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/how-do-i-print-this-printing-help/">How do I print this? (Printing help)</category>                        <dc:creator>Praza</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/how-do-i-print-this-printing-help/my-prusa-mini-cant-print-small-polygons/#post-705544</guid>
                        <link>https://forum.prusa3d.com/forum/how-do-i-print-this-printing-help/my-prusa-mini-cant-print-small-polygons/#post-705541</link>
                        <pubDate>Tue, 26 Mar 2024 17:40:28 +0000</pubDate>
                        <description><![CDATA[Yes, that could help, but other FDM printers will print this model even without such adjustments. But thank you for the advice.
 Posted by: @diem 
As the filament turns a corner it drags...]]></description>
                        <content:encoded><![CDATA[<p>Yes, that could help, but other FDM printers will print this model even without such adjustments. But thank you for the advice.</p>
<blockquote data-userid="50813" data-postid="705478" data-mention="diem">
<div class="wpforo-post-quote-author"><strong> Posted by: @diem </strong></div>
<p>As the filament turns a corner it drags some of the previously laid strand with it rounding the angle.  All FDM curves distort slightly to the concave.</p>
<p>Calibrate your hole to a slight star shape and you should be able to acheive the desired result.</p>
<p>Cheerio,</p>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/how-do-i-print-this-printing-help/my-prusa-mini-cant-print-small-polygons/#post-705541</guid>
                        <link>https://forum.prusa3d.com/forum/how-do-i-print-this-printing-help/my-prusa-mini-cant-print-small-polygons/#post-705518</link>
                        <pubDate>Tue, 26 Mar 2024 14:26:26 +0000</pubDate>
                        <description><![CDATA[Your printer need to be straight in x,y,z and from picture I can tell you its not. Its paint with this printer...]]></description>
                        <content:encoded><![CDATA[<p>Your printer need to be straight in x,y,z and from picture I can tell you its not. Its paint with this printer...</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/how-do-i-print-this-printing-help/my-prusa-mini-cant-print-small-polygons/#post-705518</guid>
                        <link>https://forum.prusa3d.com/forum/how-do-i-print-this-printing-help/my-prusa-mini-cant-print-small-polygons/#post-705478</link>
                        <pubDate>Tue, 26 Mar 2024 10:11:12 +0000</pubDate>
                        <description><![CDATA[As the filament turns a corner it drags some of the previously laid strand with it rounding the angle.  All FDM curves distort slightly to the concave.Calibrate your hole to a slight star sh...]]></description>
                        <content:encoded><![CDATA[<p>As the filament turns a corner it drags some of the previously laid strand with it rounding the angle.  All FDM curves distort slightly to the concave.</p><p>Calibrate your hole to a slight star shape and you should be able to acheive the desired result.</p><p>Cheerio,</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/how-do-i-print-this-printing-help/">How do I print this? (Printing help)</category>                        <dc:creator>Diem</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/how-do-i-print-this-printing-help/my-prusa-mini-cant-print-small-polygons/#post-705478</guid>
                        <title>My Prusa MINI can&#039;t print small polygons</title>
                        <link>https://forum.prusa3d.com/forum/how-do-i-print-this-printing-help/my-prusa-mini-cant-print-small-polygons/#post-705460</link>
                        <pubDate>Tue, 26 Mar 2024 08:03:14 +0000</pubDate>
                        <description><![CDATA[My Prusa MINI can&#039;t print small polygons. I printed this box, and instead of small hexagons, the printer printed circles. I&#039;ve tried adjusting the belt tension and slowing down the print spe...]]></description>
                        <content:encoded><![CDATA[<p>My Prusa MINI can't print small polygons. I printed this box, and instead of small hexagons, the printer printed circles. I've tried adjusting the belt tension and slowing down the print speed, but the result is still the same. Does anyone know where the problem might be?<a href="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2024/03/bda13acd-img_0832-scaled.jpeg"><img class="alignnone size-medium wp-image-165553" src="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2024/03/bda13acd-img_0832-600x500.jpeg" alt="" width="600" height="500" /></a></p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/how-do-i-print-this-printing-help/my-prusa-mini-cant-print-small-polygons/#post-705460</guid>
