Lithophane questions
getting ready to try my first lithophane. I have a couple questions. In lithophane maker it looks great. In prusa slicer it doesn't look near as good is that normal? Also should i print it at .07 ultra detail or something different?
I also set it at 100% infill any tips would be greatly appreciated! Thanks!
RE: Lithophane questions
Hi! Lithophane don't usually look good in slicers, but you could post a picture so we can help more.
Yes, you need to print at 100% infill, otherwise it will show through. The highest resolution setting helps a lot with tiny details.
Are you going to print it vertically or laying flat?
Ok great i will give it a shot and see how it turns out. Already put it on the card. Next time i slice one i will take a picture of it.
Thanks
Looks normal to me. It should come out great 🙂
turned out great!
Awesome 😀 well done!
Hi guys and girls 🙂
What are your settings in Prusaslicer, detail level and speed ?
Which color PLA do you use ? i was thinking about Snow White PLA.
Hi guys and girls 🙂
100% infill and nothing more. Level of detail: the higher, the better, but of course it's gonna take longer. I've tried grey and red lithophanes and as long as you don't make it too thick (< 4 mm, I'd say) it's going to work.
