Insect protector
atomleef
(@atomleef)
Insect protector
I have a problem with an ant enter in my computer. Then I design a pole with small water bowl at it's base. Fill an oil in a bowl and it will protect ant to climb up to my computer. I finished printing an item, I pour an oil in it, I found that oil leak out from it. How can I resolve this issue with next print?
Can 3d print item hole an solution?
Print with esunpla, prusa slicer, 0.15 quality.
Posted : 01/07/2020 4:58 pm
atomleef
(@atomleef)
RE: Insect protector
I just found some knowledge about this 😀
https://3dprintergeeks.com/pla-water-resistant/
Posted : 02/07/2020 1:28 am
Oil tends to seep into openings and spread. You might find that some dish soap works well as a barrier and will be less likely to seep through the part. If all else fails, rub the inside with candle wax.
Posted : 02/07/2020 1:48 am
atomleef
(@atomleef)
@bobstro
Thank you, I will try it 👍
Posted : 06/07/2020 2:24 pm
3Dprintedgr
(@3dprintedgr)
I think you will have better luck with waterproofing if you use PETG material.
Original Prusa Mini + Smooth PEI
Prusa Slicer 2.6.0
Posted : 07/07/2020 5:19 am
atomleef
(@atomleef)
@geoper2
Thank you, but now my printer have a problem after 30 mins print filament stop comes out, still do not know how to solve 😅😅😂
Posted : 07/07/2020 5:21 am
3Dprintedgr
(@3dprintedgr)
@atomleef
Which filament did you use?
Prusa Slicer 2.6.0
Posted : 07/07/2020 3:52 pm
