					                		How to archive perfect details and result for a small model - How do I print this? (Printing help)                                    </title>
                <link>https://forum.prusa3d.com/forum/how-do-i-print-this-printing-help/how-to-archive-perfect-details-and-result-for-a-small-model/</link>
                <lastBuildDate>Sat, 06 Jun 2026 14:16:25 +0000</lastBuildDate>
                        <title>RE: How to archive perfect details and result for a small model</title>
                        <link>https://forum.prusa3d.com/forum/how-do-i-print-this-printing-help/how-to-archive-perfect-details-and-result-for-a-small-model/#post-702399</link>
                        <pubDate>Mon, 04 Mar 2024 14:45:53 +0000</pubDate>
                        <description><![CDATA[Hi Tom, 3d Printing is a bit of an art form.there are no fixed answers. Different filaments behave in different ways. even different batches and different colours of the same make. can be di...]]></description>
                        <content:encoded><![CDATA[<p>Hi Tom, <br />3d Printing is a bit of an art form.<br />there are no fixed answers. <br /><br />Different filaments behave in different ways. <br />even different batches and different colours of the same make. can be different. <br /><br />Z lift is sometimes an issue causing strings and fluffiness Try a print without Z lift. <br /><br />I have had one filament that needed to be printed at 170C (which was a problem because the cold extrude prevention temperature is often 170C I had to lower that as well)<br /> Excess retraction is another potential cause... I generally use 2mm for  my Mk2 MMU1, which is Bowden feed like your mini. <br /><br />have you ever tried a temperature tower? <br />you might be able to print cooler. <br />Is your part cooling fan running for PLA? <br /><br />Some folk try different retraction speeds. I never had much luck with that<br />even different printers from the same manufacturer can have different requirements.<br />Oddly, My Printers with Multiple material units seem to like lower temperatures than the same model without MMU...</p><p>wet filament is another potential issue</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/how-do-i-print-this-printing-help/">How do I print this? (Printing help)</category>                        <dc:creator>JoanTabb</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/how-do-i-print-this-printing-help/how-to-archive-perfect-details-and-result-for-a-small-model/#post-702399</guid>
                        <link>https://forum.prusa3d.com/forum/how-do-i-print-this-printing-help/how-to-archive-perfect-details-and-result-for-a-small-model/#post-702395</link>
                        <pubDate>Mon, 04 Mar 2024 14:22:25 +0000</pubDate>
                        <description><![CDATA[Hi Joan, thank you for your quick answer!I&#039;ve tried it with 200° nozzle temp (instead of 210°). Filament temp should be 210-215, but this seems not to be an issue.The result looks a bit beet...]]></description>
                        <content:encoded><![CDATA[<p>Hi Joan, thank you for your quick answer!</p><p>I've tried it with 200° nozzle temp (instead of 210°). Filament temp should be 210-215, but this seems not to be an issue.</p><p>The result looks a bit beeter, but still not perfect. Meaning still some strings within the motive. Actually I'm printing a smilie emoji with yellow background on the lower layers and the eyes/mouth in black for the upper 0,5mm layer.</p><p>I'll do some more testing. Could lowering the speed help?</p><p>Thx,Tom </p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/how-do-i-print-this-printing-help/">How do I print this? (Printing help)</category>                        <dc:creator>Tom</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/how-do-i-print-this-printing-help/how-to-archive-perfect-details-and-result-for-a-small-model/#post-702395</guid>
                        <link>https://forum.prusa3d.com/forum/how-do-i-print-this-printing-help/how-to-archive-perfect-details-and-result-for-a-small-model/#post-701896</link>
                        <pubDate>Thu, 29 Feb 2024 15:49:11 +0000</pubDate>
                        <description><![CDATA[Try a lower nozzle temperature on the black, and try &#039;Avoid crossing perimeters&#039;regards Joan]]></description>
                        <content:encoded><![CDATA[<p>Try a lower nozzle temperature on the black, and try 'Avoid crossing perimeters'<br /><br />regards Joan</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/how-do-i-print-this-printing-help/how-to-archive-perfect-details-and-result-for-a-small-model/#post-701896</guid>
                        <title>How to archive perfect details and result for a small model</title>
                        <link>https://forum.prusa3d.com/forum/how-do-i-print-this-printing-help/how-to-archive-perfect-details-and-result-for-a-small-model/#post-701892</link>
                        <pubDate>Thu, 29 Feb 2024 15:23:36 +0000</pubDate>
                        <description><![CDATA[Hi there!
I&#039;ve a 30x10x3 mm (LxWxH) model where a 8x8 mm motive is carved out 0,5mm and another layer colow below is visible. 
The current results are not bad, but I&#039;m wondering how can I ...]]></description>
                        <content:encoded><![CDATA[<p>Hi there!</p>
<p>I've a 30x10x3 mm (LxWxH) model where a 8x8 mm motive is carved out 0,5mm and another layer colow below is visible. </p>
<p>The current results are not bad, but I'm wondering how can I make them perfect. There are mainly 2 issues: Stringing and no sharp borders.</p>
<p>I don't care about the printing speed. I use the standard nozzle (0,4mm) and eSun PLA+ filament and PrusaSlicer. Layer hight is 0,1mm.</p>
<p>The first priority would be to lower/remove the stringing. So is there maybe a way to use a modifier for the 8x8mm part of the model?</p>
<p>Actually the stringing in the 8x8 area is not massive. There are 3-6 strings depending on the motive. But they are in black color in front of the yellow layer below: so they are clearly visible.</p>
<p>Later options would be to change the nozzle or the printer? So additional I'd like to understand what is possible and where are the limits.</p>
<p>Thanks for your support and experience/knowledge sharing!</p>
<p>Cheers,Tom </p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/how-do-i-print-this-printing-help/how-to-archive-perfect-details-and-result-for-a-small-model/#post-701892</guid>
