					                		Holes in extruded filament - How do I print this? (Printing help)                                    </title>
                <link>https://forum.prusa3d.com/forum/how-do-i-print-this-printing-help/holes-in-extruded-filament/</link>
                <lastBuildDate>Fri, 12 Jun 2026 23:45:42 +0000</lastBuildDate>
                        <title>RE: Holes in extruded filament</title>
                        <link>https://forum.prusa3d.com/forum/how-do-i-print-this-printing-help/holes-in-extruded-filament/#post-684675</link>
                        <pubDate>Fri, 17 Nov 2023 14:44:47 +0000</pubDate>
                        <description><![CDATA[I forgot to change status to solved, I’m sorry. The problem was in the end wet filament. I changed nozzle and pfte hotend tube and the problem was still there. But then I tried completely ne...]]></description>
                        <content:encoded><![CDATA[<p>I forgot to change status to solved, I’m sorry. The problem was in the end wet filament. I changed nozzle and pfte hotend tube and the problem was still there. But then I tried completely new filament and it solved the problem. So basically I found out that my dryer doesn’t work. Thank u all for your tips.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/how-do-i-print-this-printing-help/">How do I print this? (Printing help)</category>                        <dc:creator>Brejvi</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/how-do-i-print-this-printing-help/holes-in-extruded-filament/#post-684675</guid>
                        <link>https://forum.prusa3d.com/forum/how-do-i-print-this-printing-help/holes-in-extruded-filament/#post-684553</link>
                        <pubDate>Thu, 16 Nov 2023 21:19:26 +0000</pubDate>
                        <description><![CDATA[I wonder if you damaged the nozzle when cleaning it ... try a new nozzle.Cheerio,]]></description>
                        <content:encoded><![CDATA[<p>I wonder if you damaged the nozzle when cleaning it ... try a new nozzle.</p><p>Cheerio,</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/how-do-i-print-this-printing-help/">How do I print this? (Printing help)</category>                        <dc:creator>Diem</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/how-do-i-print-this-printing-help/holes-in-extruded-filament/#post-684553</guid>
                        <link>https://forum.prusa3d.com/forum/how-do-i-print-this-printing-help/holes-in-extruded-filament/#post-684385</link>
                        <pubDate>Wed, 15 Nov 2023 22:40:39 +0000</pubDate>
                        <description><![CDATA[Hello, thank you for your reply and advice, i forgot to mention that I did the “manual flush” during the cleaning process. Unfortunately it didn’t help.]]></description>
                        <content:encoded><![CDATA[<p>Hello, </p><p>thank you for your reply and advice, i forgot to mention that I did the “manual flush” during the cleaning process. Unfortunately it didn’t help. </p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/how-do-i-print-this-printing-help/holes-in-extruded-filament/#post-684385</guid>
                        <link>https://forum.prusa3d.com/forum/how-do-i-print-this-printing-help/holes-in-extruded-filament/#post-684381</link>
                        <pubDate>Wed, 15 Nov 2023 21:32:53 +0000</pubDate>
                        <description><![CDATA[Filament is dry,
Make absolutely certain of this.
tried another one, same problem. Any ideas? Thank you.
Try a manual flush through: loosen off the extruder idler completely - tempo...]]></description>
                        <content:encoded><![CDATA[<blockquote>
<p>Filament is dry,</p>
<p>Make absolutely certain of this.</p>
<blockquote>
<p>tried another one, same problem. Any ideas? Thank you.</p>
<p>Try a manual flush through: loosen off the extruder idler completely - temporarily disconnect the PTFE tube from the extruder - heat to the print temperature of the hottest printing filament you use.  Take a metre of PLA and push it down through the hotend by hand - first slowly then as fast as it will go - finally pause for a second then pull out the end as fast as you can.</p>
<p>This procedure should dislodge any recalcitrant filament residues.</p>
<blockquote>
<p>don’t mind the first layer, Z offset was not calibrated yet.</p>
<p>OK, let the hotend cool and reconnect/retension everything before calibrating.</p>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/how-do-i-print-this-printing-help/holes-in-extruded-filament/#post-684381</guid>
                        <title>Holes in extruded filament</title>
                        <link>https://forum.prusa3d.com/forum/how-do-i-print-this-printing-help/holes-in-extruded-filament/#post-684313</link>
                        <pubDate>Wed, 15 Nov 2023 14:59:24 +0000</pubDate>
                        <description><![CDATA[Hello, few days ago i had a print failure, the nozzle got clogged and the extruder milled the filament. So i took extruder apart cleaned it, unclogged nozzle and cleaned it as well + used co...]]></description>
                        <content:encoded><![CDATA[<ul><li><a href="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2023/11/d7658224-img_2322-scaled.jpeg"><img class="alignnone size-medium wp-image-159714" src="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2023/11/d7658224-img_2322-600x500.jpeg" alt="" width="600" height="500" /></a>Hello, </li></ul><p>few days ago i had a print failure, the nozzle got clogged and the extruder milled the filament. So i took extruder apart cleaned it, unclogged nozzle and cleaned it as well + used cold pull method. Then I wanted to do a test print. But it didn’t go well as u can see on the photo. So i cleaned the nozzle again, removed and cleaned the PTFE hot end tube and the problem it’s still there. Filament is dry, tried another one, same problem. Any ideas? Thank you. <br />P.S. don’t mind the first layer, Z offset was not calibrated yet.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/how-do-i-print-this-printing-help/holes-in-extruded-filament/#post-684313</guid>
