gcode parameters don't match print
If you look at our gcode, the x axis should measure 149 mm and the y axis should measure 99 mm. We stopped the print after the border in order to save filament. As you can see, the x axis actually prints at 139mm (10mm short) and the y axis prints out at 89mm. Any idea why these 10mm would be getting shaved off in the transfer from gcode to print?
Best Answer by René:
The difference you notice is correct.
The size 149x99mm in Prusaslicer is the size included the protrusions on the tray.
The size of the container without the protrusions is 140x90mm
RE: gcode parameters don't match print
No specific ideas but if you want to upload a zipped 3mf file of your project we can take a look to see if there's anything strange. Also, do you print from card, Prusaslicer directly, or Octoprint?
https://drive.google.com/file/d/1-fsSocTuTRO7RQpGExwCOt2dxXuvCnHb/view?usp=sharing
Thanks for helping - here's the link to the 3mf file.
Oh, that makes sense! I'll have my student revise their model with that in mind. (Insert forehead smack here...)
