File (gcode) not showing up on list of available files to print (mini+)
Johnsorm
(@johnsorm)
I am trying to print an object that has the dimensions X=6.79 Y=3.74 and Z= 0.39 inches on my mini+.
I disable the skirt from the print so there is not an outline around the object. When I export the gcode to my usb (file attached), the printer does not list this file. I'm assuming it is because of the dimensions of the object, but is there anyway to get this to print? This is for a component for my table saw and needs to fit tightly, so therefore I cannot shrink the dimensions any further (this is one part of a two part assembly that I can't safely break into 3 objects.
Thank you for your help
Posted : 26/12/2021 10:41 pm
Johnsorm
(@johnsorm)
RE: File (gcode) not showing up on list of available files to print (mini+)
Problem is solved, there was a symbol in the middle of the filename that kept it from showing up. D'oh!
Posted : 27/12/2021 12:27 am
