Different distance between extruded lines problem - Mini
Weird title, not sure what it's called but I have an issue where there's a little bit of curling and the distance between lines are different depending on where on the heatbed the printed part is. My prime suspect was that there might have been a slight tilt on the XZ axis but I couldn't verify any issues in that regard after following Prusas "squaring" guide.
I'm using the default Prusa profiles (0.20mm quality), 0.4 nozzle and PLA in this case on a Prusa Mini and I have of course followed the guidelines for cleaning the printsheet with isopropyl alcohol etc.
Any suggestions on what I could look into here?
Publié : 30/04/2023 4:41 pm
