2 Minis, printing differently
Adamaarts
(@adamaarts)
I have two Minis, both have performed wonderfully for the last couple years. I normally use Prusa galaxy black PLA with absolutely no issues.
Recently I have been attempting to make some dual color filament pieces, dragons and eggs. I attempted using MatterHackers Build PLA dual color filaments, and it’s been rough.
One printer seems to print without any sort of issue, other than the filament leaving a stain on the bed. The other printer seems to always clog at around layer 3-5 and sometimes later. But with this filament it clogs every time. I’ve tried temps from 195-220 and it seems to happen the same way.
I figured it’s heat creep so I tested the fans, cleaned out all the dust, and it still happens the same. But if I switch back to Prusa pla it works fine again.
Any help on this?
This topic was modified 2 years ago by Adamaarts
Posted : 21/03/2024 3:26 pm
Bob
 Bob
(@bob-2)
RE: 2 Minis, printing differently
Sounds like heat creep.  When was the last time you looked at or changed the PTFE tube in the hot end?  They can shrink and when they do a gap opens in the heat break that fills with filament.   The matter hacker may be more sensitive to it.
Cheers
-Bob
Posted : 21/03/2024 6:00 pm
Adamaarts
(@adamaarts)
I didn’t see any filament or damage or anything abnormal when I cleared the last jam. I will try to replace that tube just to be safe.
Posted : 21/03/2024 6:38 pm
Bob
 Bob
(@bob-2)
I had such a problem with it I changed my heat break with a Bondtech, it raises where the PTFE meets the break so it's less susceptible to heat.
Cheers
-Bob
Posted : 21/03/2024 9:12 pm
Adamaarts
(@adamaarts)
I took out the old PTFE tube and it definitely was getting a tiny bit worn, and there was a small amount of filament build up in the hot end. Got it cleaned and changed the PTFE tube, so far it’s working!
Thanks for the help!
Posted : 21/03/2024 10:53 pm
Peter_B
(@peter_b)
What I found out is that the amount of thermal paste on heatbrake inside the hotend heatsink is not sufficient out of factory, so hence heat creep. I disassembled it, remove old paste and apply new one according to manual https://help.prusa3d.com/guide/how-to-replace-a-heaterblock-heatbreak-mini-mini_122769 step 15. After that everything is ok in stock configuration even after printing PC at 285 C for long periods of time.
Regards,
Peter
Posted : 22/03/2024 6:07 pm
