Z Axis Problem
On the self test shows fail i`ts go ups i`ts go down and shows fail
Opublikowany : 18/12/2021 12:58 pm
1 ludzie polubili
RE: Z Axis Problem
Your Z axis self-test fails? Sounds like what I ran into on my inital tests after building my Mini.
The Z-axis moved up and down, and seemed ok. But in the initial self-test process it failed. After doing some searching around here and on the net, I found that I had over tightened the screws on the trapezoidal nut. Those need to be just tight enough to keep it from rattling. Try loosening them and test again.
Mini+ (kit) - Revo Micro | Antler Cooling | WiFi (4.4.0RC1)
Opublikowany : 20/12/2021 3:51 pm
Topic starter
answered:
RE: Z Axis Problem
tnx i will try it 🙂
Opublikowany : 20/12/2021 4:12 pm
