Y axis motor jumping
As video
what's happening?
RE: Y axis motor jumping
https://forum.prusa3d.com/wp-content/uploads/2021/12/VID-20211230-WA0011-1.mp4
why is my video not showing...
so the y axis motor will skip/jump when the bed is moved to either end.
at 0:04, you can see that it skips/jump
it happens when the bed is moved to the extreme ends, during printing or end of self-calibration
it does not happen when I move the bed by hand.
it does not happen when I move it through LCD > settings > move axis.
https://help.prusa3d.com/en/article/adjusting-belt-tension-mini_157324
to tighten or loosen?the belt is not slipping.
Probably tighten.
Probably tighten.
I have tighten the belt.
motor is still jumping
this jumping did not happen during axis selfcheck.
is the motor faulty?
The motor is probably OK.
Take this to Prusa Support: Log into your Eshop account, navigate to support and live chat is at bottom right in most browsers. If not you may need to disable your ad-blocker temporarily.
When this happened to me, it was a bit a filament got lodged on the gear (under the belt - so it was very hard to see). Once I removed the stuck filament chunk, everything went back to normal.
